refurbished receiver with audessey... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-26-2013, 01:45 PM - Thread Starter
LAVIATHAN's Avatar
looking for a refurbished 5.1 receiver. trying to save a little money. i need pre-outs, atleast 5 hdmi connects, and android app. ive been searching on ACCESORIES4LESS. budget is $400. seems like i find the perfect receiver and then... it doesnt have pre-outs. i have a Emotiva XPA2. like to have plenty of power to my mains. thanx
LAVIATHAN is offline
post #2 of 11 Old 10-26-2013, 02:50 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Increase your budget by at least $300.
arnyk is offline
post #3 of 11 Old 10-26-2013, 02:51 PM - Thread Starter
LAVIATHAN's Avatar
ok... suggestions?
post #4 of 11 Old 10-26-2013, 03:23 PM - Thread Starter
LAVIATHAN's Avatar
post #5 of 11 Old 10-26-2013, 05:53 PM - Thread Starter
LAVIATHAN's Avatar
thanx for the help. this forum is awesome!
post #6 of 11 Old 10-26-2013, 11:00 PM - Thread Starter
LAVIATHAN's Avatar
post #7 of 11 Old 10-26-2013, 11:06 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I was going to help you, but then I noticed your tantrum and thought better of it. Good luck.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #8 of 11 Old 10-26-2013, 11:19 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you only need preouts for your XPA2 then get a slimline Marantz. It has preouts for the front channels.
Marantz 1603. Has preouts for the mains only but that's all you need for your XPA2.
http://www.accessories4less.com/make-a-store/item/MARNR1603/MARANTZ-NR1603-SlimLine-AV-Receiver-7.1ch-with-Networking-and-AirPlay/1.html
Afro GT
afrogt is offline
post #9 of 11 Old 10-26-2013, 11:31 PM - Thread Starter
LAVIATHAN's Avatar
hmmm... nice suggestion. i think im sold on the Yamaha V671. i'll get this if it has preouts  http://www.amazon.com/Yamaha-RX-V671-7-1-Channel-Network-Receiver/dp/B004QR56SE/ref=sr_1_2?ie=UTF8&qid=1382850819&sr=8-2&keywords=RX-V671
post #10 of 11 Old 10-27-2013, 04:45 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
apologize for your tantrum and maybe i will make a better effort to help you.
67jason is offline
post #11 of 11 Old 10-27-2013, 08:02 AM
afrogt's Avatar
Liked: 755
That RX-671 has a set out audio outs, not preouts. Those audio outs wont work with digital sources so you're out of luck.
If you're willing to spend $450 or $500 look at the Marantz 5006 or 5007.
The 5006 has front preouts and the 5007 had a full set of preouts. And they use Audyssey MultEQ XT. That Yamaha 671 uses YPAO which isn't as good in my opinion.
http://www.accessories4less.com/make-a-store/item/MARSR5006/Marantz-SR5006-AV-Receiver-with-Networking-and-AirPlay/1.html
http://www.accessories4less.com/make-a-store/item/MARSR5007/MARANTZ-SR5007-100w-x7-NetworkingTheater-Receiver-w/AirPlay-3D-4K/1.html
Afro GT
afrogt is offline
