Enabling SW2 after Audessey - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-26-2013, 04:11 PM - Thread Starter
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Hi All
I bought a Buttkicker LFE Kit and addition transducer a few weeks ago. love them, but the amp sucks as far as control goes. All my gear is in the basement and I have to constantly adjust the gain on the BK amp because movies have wildly varying LFE levels (e.g. Safe House LFE seems almost non-existant, but Oblivion is outstanding). Clearly, I'm not going to keep running up and down stairs to tweak the gain on the LFE amp. I temporarily placed it in the media room next to the sub using a splitter, but really want to get it back in the basement. I'm currently using 1 sub (SVS PB Ulttra-13), so I figured I'd use SW2 output and adjust the level on that to adjust the BK transducer level.
I enabled 2 subs, but then it turns off audyssey and I get no output from sub 2. I obviously can't run audyssey having told it to measure 2 subs when I only have one. I *could* disconnect SW1 and connect to SW2 when it's measured SW1 and is moving to SW2, but not sure what it will do if I'm tricking it into thinking I have 2 subs.
Anyone got any suggestions of how I can get SW2 enabled when Audessey is configured for one (or an alternate method to vary the input to the ButtKicker LFE - for example, split the LFE at AVR out, send half to sub and half to some kind of amp that has remote control capability, and from that device to the LFE amp)?
TIA
Mark
mark_anderson_u is offline
post #2 of 3 Old 10-27-2013, 07:33 AM
Selden Ball's Avatar
Quoted: 3492 Post(s)
Liked: 1763
That sub has both left and right channel inputs. I think that connecting sub1 out to the right and sub2 out to the left, then running Audyssey would cause both of the receiver's sub outputs to calibrate properly.
However, using an external Y cable on the single calibrated output should work just as well.
Selden
Selden Ball is online now
post #3 of 3 Old 10-27-2013, 08:16 AM - Thread Starter
Quoted: 43 Post(s)
Liked: 42
will give it a try
Svs Pb13 Ultra
