Possible to insert an equalizer into a loop with Yamaha RX-V871 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-27-2013, 12:33 AM - Thread Starter
beatnut88's Avatar
like all modern receivers Yamaha RX-V871 doesn't have a tape monitor loop allowing for the insertion of an equalizer. It has a pre-out but no main in. Am I whistling Dixie here?
beatnut88 is offline
post #2 of 11 Old 10-27-2013, 01:13 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Yes, unless you have outboard amps. That would allow you to put the equalizer between the preouts and the amps. The AVR should have all the equalization capability you need.
FMW is offline
post #3 of 11 Old 10-27-2013, 02:00 AM - Thread Starter
beatnut88's Avatar
Yes, but kinda defeats the purpose of spending all that dosh on a receiver - as well as adding another level of complexity. Fortunately the TV/Video comes from a PC so the sound goes thru the EQ and Exciter before the AVR. THe AVR has Para-EQ but you cannot change it quickly as with a dedicated EQ. I had to study for a science degree to set the whole thing up.
Neil
post #4 of 11 Old 10-27-2013, 08:08 AM
FMW
FMW's Avatar
Liked: 1681
I'm guessing you should study some more.
FMW is offline
post #5 of 11 Old 10-27-2013, 08:25 AM
newirishman's Avatar
Liked: 31
I guess what FMV is trying to say is that the 871 comes with YPAO which is a automated room EQ hence it is not entirely clear why you would would want to add an external EQ.
newirishman is offline
post #6 of 11 Old 10-27-2013, 02:48 PM - Thread Starter
beatnut88's Avatar
The YPAO is a sales gimmick. Use that and watch the bass disappear completely.
Neil
post #7 of 11 Old 10-27-2013, 04:30 PM
FMW
FMW's Avatar
Liked: 1681
Neil
Or, more accurately, set the bass at the proper level. Most amateurs use way too much bass in their playback. It reminds me of those cars going by leaving behind those thum-thump sounds.
FMW is offline
post #8 of 11 Old 10-27-2013, 04:31 PM
jontyrees's Avatar
Liked: 38
I'm kinda with you on this - although I have no experience with the Yamaha YPAO program. I used MCACC on my Pioneer VSX-1121, and thought the results were terrible. Took all the life out of an excellent receiver. As soon as I went in and manually adjusted all the eq's and channel levels, it was like a new machine - audio is now lively, full and colorful, and I don't feel like "I'm supposed to like it this way, even though I don't" As you say, it dialed the bass down to where it was non-existant - it was just a bunch of flat mids - like a Bose system. Anyway, enough slamming auto-correction - my question is what kind of equalizer are you using? Is it 5.1, 7.1? If it's only stereo, would you only be able to affect two channels? What kind of inputs and outputs does it have?
I'm pretty sure your receiver will allow you to manually set all your eq's - may just have to dig for it in the settings somewhere. The manual eq settings for Pioneer were somewhere in the MCACC setup - which is counter intuitive, but that's where they put them
jontyrees is offline
post #9 of 11 Old 10-27-2013, 06:39 PM - Thread Starter
beatnut88's Avatar
Just stereo - 2 speakers. The equalizer is an oldie but a goodie. The behringer exciter is actually more important in terms of sound. The Yamaha replaced a previous Denon unit that was cheaper and sounded better - it's impossible to get good bass out of the Yamaha without inserting enhancers or fiddling with the poorly implemented in-built para eq (impossible to use on-the-fly). But the Denon didn't have HDMI or sufficient inputs. Surround I can live without as I don't watch the sort of shows that employ it to any effect.
Neil
post #10 of 11 Old 10-28-2013, 07:15 AM
FMW
FMW's Avatar
Liked: 1681
Well, there are always subwoofers.
FMW is offline
post #11 of 11 Old 10-29-2013, 07:11 PM - Thread Starter
beatnut88's Avatar
nothing to do with speakers. solution is to put everything thru the media centre PC which then plugs into the exciter and eq and then the amp. all the fake surround stuff is then set up on the PC. Set the AVR to pure direct. basically I've blown a grand on the AVR as I could have done this with the better-sounding Denon and HDMI box. live and learn I guess.
Yamaha Rx V871 Receiver
