New XPA-5 arriving tomorrow - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ClawAndTalon
post #1 of 14 Old 10-27-2013, 02:55 PM - Thread Starter
Slingblayde's Avatar
Liked: 64
Ordered one of the Emotiva XPA-5 Gen 2 amps on Thursday, they are on sale for $100 off, I'm pumped. It gets delivered tomorrow along with the one of the trigger units, and rack ears. I can just get some regular RCA's from Monoprice to go from the Onkyo 818 to the amp correct? Im going to use some crappy Red/White cables that I have in the old "Wire Box" that everybody seems to accumulate over time, until I get some decent ones online.
I want to use the amp so I can run a 9.2 setup, does anybody have a rule of thumb for how high the Front Height speakers should go? I bought a pair of speakers to mount either in the walls, or in the ceiling for heights but I'm not exactly sure how high I am supposed to mount them. Do they get mounted the same width as the fronts, just straight up higher on the wall?
Any advice would be appreciated.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #2 of 14 Old 10-27-2013, 09:35 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Can I ask what speakers you are using and why you bought a amp?
I have a 818 with Logan motion 12 fronts 4 motion 10s for sides and rears a motion c center and r subs.
My center channel seems to be lacking and sounds distorted at high volume I wonder if it's because lack of power
Holiday121 is offline
post #3 of 14 Old 10-28-2013, 03:30 AM - Thread Starter
Liked: 64
The 818 can do 7.2 natively, but to do 9.2 it needs an external amp, So I bought the 5 channel amp to power the 3 fronts, and 2 side surrounds, then I will let the receiver power the remaining 4. Our 818's power rating is 135w/channel when there is only 2 channels driven, the more speakers we hook up, the lower the power to each one is.
I have Klipsch speakers all the way around in my setup, RB-61's for fronts, RC-62 for center, and RS-41's for sides and surrounds, then 2 PSA XV-15 subs.
post #4 of 14 Old 10-28-2013, 05:23 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Ahhh I see so are subs included in those what's or no since I have powered subs?
So adding 5 more speakers takes it down to like 40 watts a per channel then?
post #5 of 14 Old 10-28-2013, 03:50 PM - Thread Starter
Liked: 64
The powered subs have their own amp built in, all they do is receive the signal and the amp takes care of the rest.
I'm not sure what the total wattage per channel after I hook all my speakers actually is, but Im guessing its pretty low.
post #6 of 14 Old 04-18-2016, 07:00 PM
bpassman's Avatar
Quoted: 114 Post(s)
Liked: 46
Originally Posted by Slingblayde View Post
Ordered one of the Emotiva XPA-5 Gen 2 amps on Thursday, they are on sale for $100 off, I'm pumped. It gets delivered tomorrow along with the one of the trigger units, and rack ears. I can just get some regular RCA's from Monoprice to go from the Onkyo 818 to the amp correct? Im going to use some crappy Red/White cables that I have in the old "Wire Box" that everybody seems to accumulate over time, until I get some decent ones online.<br><br>
I want to use the amp so I can run a 9.2 setup, does anybody have a rule of thumb for how high the Front Height speakers should go? I bought a pair of speakers to mount either in the walls, or in the ceiling for heights but I'm not exactly sure how high I am supposed to mount them. Do they get mounted the same width as the fronts, just straight up higher on the wall?<br>
Any advice would be appreciated.<br><br>
Sling <img alt="smile.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/smile.gif">
Did you get your XPA-5 and get it mounted in a rack? If so, how did you mount the rack ears on the gear?
Brad
AVR Anthen AVM 60 Amp Emotiva XPA-7 & XPA-5 Sources Oppo 103D, FiOS
Speakers Atmos 7.2.4 - TruAudio B23-465s (LCRs), TruAudio B23-265s (SL/R & SB), Dual SVS PC-2000s (Subs), 4 In Ceilings
PJ JVC RS500 Screen 153" DIY 2.35:1 Spandex
My crazy long build Coffered Ceiling
bpassman is offline
post #7 of 14 Old 04-18-2016, 07:24 PM
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
Sling
Look around on Amazon for close outs on component cables (RGB) and just don't use one of them.
As for the amp. It's way bigger than it looks online, and it's absolutely a boat anchor. Not all entertainment centers are good to hold it.
Hairsonfire likes this.
ClawAndTalon is offline
post #8 of 14 Old 04-18-2016, 08:39 PM - Thread Starter
Liked: 64
I bought the Amp, and already had a MA Slim rack to mount it in, I ordered the rack ears for that amp and it mounted up perfect. Almost gave myself a hernia trying to lift it in the rack myself, I bribed the neighbor with Beer to come and help me install it. I also bought the UPA-700 to power the rest of the surround speakers.
Name:	Emotiva 008 resize.jpg
post #9 of 14 Old 04-18-2016, 08:46 PM
cswiger's Avatar
Quoted: 212 Post(s)
Liked: 84
Thumbs up for rack-mounting heavy gear. However, I hope you have active ventilation for these amps...?
Otherwise, please help your nice new amps live longer by giving them several inches of clearance space.
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #10 of 14 Old 04-19-2016, 07:02 AM
bpassman's Avatar
Quoted: 114 Post(s)
Liked: 46
Nice! I just picked up a XPA-7 from and AVS member and have now ordered an XPA-5 too! I'll post pics once I get them in a rack.
Brad
bpassman is offline
post #11 of 14 Old 04-19-2016, 11:22 AM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Agree on sticking at least a 1U spacer if not 2U above the amps to give them some breathing room, and fans would help circulate cool air past them.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #12 of 14 Old 04-19-2016, 05:25 PM
bpassman's Avatar
Quoted: 114 Post(s)
Liked: 46
Well..I just racked my XPA-7 using the URE-5 ears. There were no instructions with the kit, soI left the feet on. A minimum of 1U is required if the feet stay on. I'm putting a vented 2U below the XPA5, a vented 2U between the XPA5 and XPA7, and a vented 1U above the XPA7 before a 4U with my new AVM60. I'll post some pics once I get the XPA5 racked.
B
Sent from my SM-T800 using Tapatalk
Brad
bpassman is offline
post #13 of 14 Old 04-19-2016, 07:41 PM
Cutler's Avatar
Quoted: 41 Post(s)
Liked: 26
B
Sweet man, the AVM 60 seems to be a good value.....can't wait to see the finished product
Cutler is offline
post #14 of 14 Old 04-19-2016, 08:41 PM
bpassman's Avatar
Quoted: 114 Post(s)
Liked: 46
B
Here's some pics of racking the XPA-7 and blanking panels. Note, you can see the XPA-7 feet behind the 2U vented panel.
ID:	1392626   Click image for larger version
ID:	1392634   Click image for larger version
Brad
bpassman is offline
Emotiva Xpa 5 5 Channel Power Amplifier
