The "Official" Sherbourn PA 7-350 Amp Discussion Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #211 of 227 Old 09-05-2014, 10:28 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
Oh man, I wish I could pick up another one of these brutes. I tried to get a second one during the sale, but by the time I went back they were all gone. Oh well, feel pretty lucky to have one. It's a monster. Someone's going to get a good deal.
BllDo is offline
post #212 of 227 Old 09-05-2014, 03:16 PM
jdlynch's Avatar
Quoted: 160 Post(s)
Liked: 66
Originally Posted by Jeff in Canada View Post
I have to go to Indiana (Kokomo) in a couple weeks for work, so I'm able to meet up with people in Indiana, Michigan and a fair bit of Ohio (Western side)
Hi Jeff.
I live in Indiana and am often in the Indianapolis area. I am seriously considering making a deal with you and meeting somewhere for a cash deal.
David
Current Equipment: Datasat LS10 w/ Atmos and DIRAC. Datasat RA7300, Aerial Acoustics LR5's (LCR), Aerial Acoustics LR3's (sides), RBH in-walls (rears), Seaton Submersive, Marantz VP15s1, 106" Carada BW screen, Oppo BDP-103.
knobstoneaudio.com
jdlynch is offline
post #213 of 227 Old 09-19-2014, 12:10 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
Question 7-350 Power requirements ?
Hi Guys,
I'm wondering if someone here can kindly help me make the right decision as I am in the middle of installing my system.
My 7-350 is on a dedicated 220V/30A circuit (as required and mentioned in the PA 7-350 manual). However, I am faced with a bit of a dilemma. As I get voltage fluctuations in the power grid, I am thinking of incorporating a voltage stabilizer to get constant 220V at all times. The problem I have is that a 20A stabilizer is reasonably priced but a 30A stabilizer is proving to be far too expensive.
I know lab conditions demands proper 30A at 220V for optimal results but will a 20A stabiliser in the mix be sufficient for movies and music considering the fact that I will be using seven 4 ohm speakers ?
Any help will be appreciated.
Sam Ash is offline
post #214 of 227 Old 09-20-2014, 10:28 AM
Joel Solid's Avatar
Originally Posted by Sam Ash View Post
Hi Guys,
I have mine on a dedicated 20amp circuit and I have equipment to monitor what the amperage the amp pulls. I have never seen the amp pull over 10amp. My speakers are 4 ohm 87db. That is playing at reference level. The only way I can see pulling more is if you were trying to pull more amps out of it with a sine wave or if you were running your speakers all in full range. Because of my subs I have all of my speakers crossed over anywhere from 60 to 80 hz.
I hope this helps!
Joel Solid is offline
post #215 of 227 Old 12-09-2014, 08:02 PM
rms8's Avatar
Quoted: 488 Post(s)
Liked: 317
So are there people that do NOT get a buzz on the PA 7-350? I got mine last year and just got it all connected a few months ago after finally completing my HT. It has a distinct buzz which is being generated from the amp. I have proven this by not only disconnecting all inputs cables, but also by flipping off the breakers to all other devices in the sub panel. So the only thing getting power was the Sherbourn.
The speakers which are connected are not high efficiency speakers. I get the buzz in any of them. VERY DISAPPOINTED. I called Emotive today and spoke to Chad. Not a very courteous person. He said send it back to have them look at it and emailed me an RMA. Then I found this thread with others who have the same buzzing going on.
Did anyone ever send their back in for repair????????
*DIY ConcreteBunker Rustic Dream Build w/11' screen, 11.2chnl, 8x18" IB subs, 28.8KW*
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
rms8 is online now
post #216 of 227 Old 12-09-2014, 11:22 PM
Sam Ash's Avatar
Quoted: 216 Post(s)
I hope this helps!
Thank you very much for that information Joel, it helped a lot.
Sam Ash is offline
post #217 of 227 Old 12-09-2014, 11:27 PM
Sam Ash's Avatar
Quoted: 216 Post(s)
Sorry to hear that you're faced with that problem. Maybe you could borrow a single alternative efficient speaker and see if the problem still occurs. Hope you are able to resolve the issue.
Sam Ash is offline
post #218 of 227 Old 12-10-2014, 05:10 AM
rms8's Avatar
Quoted: 488 Post(s)
Liked: 317
Unhappy
Unfortunately this is an issue with the amps power supply. I have 4 different speakers connected to it and all produce the same buzz which is VERY audible from the MLP. My HT is on the larger size so the MLP is a fair distance from the speakers.
rms8 is online now
post #219 of 227 Old 02-24-2015, 01:08 PM
Viruscwu's Avatar
Quoted: 96 Post(s)
Liked: 84
So I am in the same boat. I just recently upgraded my speakers from an 87db efficiency to 99db efficiency. So what used to be barely audible a few feet away is now annoyingly audible anywhere in the room.
Were you able to get Emotiva to fix your issue?
PS - Great home theater build! Very interested in your isolated riser solution.
Viruscwu is online now
post #220 of 227 Old 03-29-2015, 08:09 PM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
How are you guys supporting the back of these amps in a rack?
The Plains Theater Has Begun
J_P_A is offline
post #221 of 227 Old 03-29-2015, 08:50 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
I'm just hanging it off the rack ears.
J_P_A likes this.
BllDo is offline
post #222 of 227 Old 03-30-2015, 06:36 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
wow! That's impressive. I built my rack using DIY rack rails. I'm a little hesitant to hang that much weight off of it.
J_P_A is offline
post #223 of 227 Old 04-06-2015, 12:29 PM
canadian_eh's Avatar
I was wondering if anyone has experience with using one of these with difficult load speakers on all 7 channels? I am considering putting together a system with a set of McIntosh XRT20 mains, two pairs of XR19's for the rear channels. I am debating as to whether or not to run a center channel. Will this amplifier properly drive these speakers? I realize I will have to run a separate 20amp circuit which I am more than willing to do if this amplifier will work. Both the XR19's and XRT20 are power hungry and about 86 db efficient. Any help/suggestions would be appreciated.
canadian_eh is offline
post #224 of 227 Old 04-07-2015, 07:54 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
I don't think it will be a problem, you will need a 20amp circuit though.
canadian_eh likes this.
Sam Ash is offline
post #225 of 227 Old 07-02-2015, 10:43 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
Has anyone figured out a way to deal with the hum? I "may" have the issue with my amps. There's definitely some buzz, but I haven't ruled out ground loop yet.
J_P_A is offline
post #226 of 227 Old 07-14-2015, 04:33 PM
Viruscwu's Avatar
Quoted: 96 Post(s)
Liked: 84
I finally sent my amp back in for repair. They sent me the following information about what they found:
Thank you for sending in your PA-7-350 unit for repair; RMA number xxxxx. I wanted to send you a quick
email to let you know what we found to be causing your problems.
Repairs completed:
Replaced input board and tested unit.
Unit passed bench functionality test.
My amp is very quiet now...comparatively. I have to stick my ear in front of my cd to hear any noise (~1-2ft away). Considering I could hear the hum >20ft away before this is a win!
I made sure the sound was coming from the amp before paying $100 to send it in to Emotiva. I was getting a very loud hum with only the speakers connected to the amp (no RCA/XLR connected).
That said I
also had to use a cable ground loop isolator for a separate issue. That buzz would happen even with the speakers connected directly to my AV receiver.
If you have a receiver it may be worth connecting your speakers directly to that to see if you still hear your hum.
post #227 of 227 Old 12-04-2016, 10:28 PM
creimes's Avatar
Quoted: 54 Post(s)
Liked: 55
I see there hasn't been any posts on this thread for quite some time now, I've read through most of it and it seems as though this is one great amplifier, I have been on the search for one of these since the closeout price and finally was able to acquire one at a really great price and now I'll be impatiently waiting for it to arrive haha. I've owned many Emotiva amps so I'm sure it will sound pretty much the same other than having a little more headroom, I'm stoked to throw on my Nine Inch Nails Blu-ray and crank it up.
The rear panel just pretty much speaks for itself lol...
Processor - Marantz AV7702, Speakers - Chane A5rx-c (LCR), UAC-8.2 rears. Subs - Mach 5 IXL-18's. Amps - Sherbourn PA 7-350, Sanway DA-5004, D2L-SUB4. Sources - Mac Mini, Oppo 103. Display - Epson 3500, Screen - DIY AT Spandex 100"
creimes is offline
Sherbourn
