Looking to upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-30-2013, 07:22 AM - Thread Starter
dboyd44's Avatar
I am currently using an Onyko 805 no problems. Just want one with hdmi pass thru  arc  and good video upconversion at least two zones "patio Speakers" and about the same power output.
dboyd44 is offline
post #2 of 11 Old 10-30-2013, 07:29 AM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Do you have a price range / price max in mind?
I'd suggest the Denon AVR-X4000, but it doesn't have the same power rating specs as your Onkyo, although it does have multi-channel pre-outputs so you could always add an external amp if you needed more power.
eljaycanuck is offline
post #3 of 11 Old 10-30-2013, 01:45 PM
Hopinater's Avatar
Quoted: 2344 Post(s)
Liked: 5904
I recently switched from an Onkyo 809 to the Denon 3313 and have been very happy with the SQ. I also have a Marantz in another system and am very happy with that as well. What's your budget and your power needs?
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203
Denon X4200 - Panamax M4300 - Apple TV - Xbox360 - Crowson Motion Actuator's
Hopinater is offline
post #4 of 11 Old 10-30-2013, 01:51 PM - Thread Starter
dboyd44's Avatar
using an 805   just ordered a 3313 hope it works out and is as reliable as the onyko that it will replace .. 110 watts using Klipsch RC62 for center and RB61 for front and Bose cubes for rear and surround.
dboyd44 is offline
post #5 of 11 Old 10-30-2013, 01:56 PM
jdsmoothie's Avatar
Quoted: 15372 Post(s)
Liked: 7517
The 3313CI uses the same version of Audyssey MultEQ XT as do both the 805 and 809, so audio quality should be similar. As eljay suggested, the better upgrade would have been the new X4000 which not only has a a few more features (to include HDMI/optical/digital coax to Zone 2) but also uses the much more advanced version of Audyssey MultEQ XT32 with 32x the speaker filter resolution as XT.
X4000 vs 3313CI:
Pro: Network diagnostics; Input Assign (analog audio inputs); Expandable to 9CH w/external 2CH amp; MultEQ XT32, Sub EQ HT (dual subs); 11.2 main zone pre-outs; Audyssey LFC, DTS Neo:X (9.2); Audyssey DSX (9.2); HDMI Video Select (USB, Tuner, Network + CD + Phono); InstaPreview (HDMI – 2D); Zone 2 HDMI Audio (Through/PCM – PCM 2.0 to Zone 2 speaker posts/pre-outs); Optical/Coax digital PCM 2.0  Zones 2/3; All Zone Stereo (Zones 2/3); 2nd Analog Devices DSP
Con: None
jdsmoothie is offline
post #6 of 11 Old 10-30-2013, 03:35 PM
Hopinater's Avatar
Liked: 5904
 Con: None
Well there is one con and it can be a big one depending on one's budget. COST. Right now the 3313 can be had for almost half of what the X4000 costs because it's last years model and Denon is dumping them. I got mine for $700. True the new Audyssey XT32 is a big plus and if you have the extra $600 then I agree, buy the X4000. But if you don't then the 3313 is a good choice. I really like the 3313 over my Onkyo 809, (even though they have the same Audyssey). To me the Denon sounds much clearer and has better SQ. But that truly is just my opinion and I know that a lot of Onkyo owners would argue against me on that. But I really like the SQ I get from both my Denon and my Marantz.
post #7 of 11 Old 10-30-2013, 04:00 PM - Thread Starter
dboyd44's Avatar
thanks for the info. I had tried the Yamaha 2020 very nice but "squirrely" when I would try to use it with my Samsung tv the receiver would turn on then off and come up on audio 1 . I would have to switch it to video 1. also changing channels with my direct tv . It would loose video and I would have to reacquire video 1. Called both Crutchfield and Yamaha support no help. Yamaha tell me problem sounds like Samsung. but old 805 no problem. Just want hdmi pass thru. Crutchfield says buy a
$200+ universal remote.
dboyd44 is offline
post #8 of 11 Old 10-30-2013, 06:10 PM
Hopinater's Avatar
Liked: 5904
I think you will be happy with the 3313. It will meet your needs and it sound great and it has a great price.
post #9 of 11 Old 10-30-2013, 07:10 PM
jdsmoothie's Avatar
Liked: 7517
For your next purchase,, suggest you give me a call at AVScience as we are both Denon and Yamaha authorized dealers, and I would very likely have resolved both of your issues/concerns had you purchased from us. wink.gif
post #10 of 11 Old 10-30-2013, 07:35 PM
tuleyoil's Avatar
tuleyoil is offline
post #11 of 11 Old 10-30-2013, 08:41 PM
Hopinater's Avatar
Liked: 5904
jdsmoothie that is great to know, I don't know about the OP but I know that when it comes to my next AVR upgrade I will call you first for both advice and possible purchase.
Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Denon Avr X4000 7 2 Channel Home Theater Receiver , Onkyo Tx Nr809 , Denon Avr 3313ci Receiver , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
