DENON AVR-2802 no speaker output, - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 10-31-2013, 11:12 AM - Thread Starter
A240494's Avatar
Denon AVR-2802 powers up warms up, everything seems fine but no output to speakers found 7 fuses seem OK, would appreciate any help. Thank you
A240494 is offline
post #2 of 18 Old 10-31-2013, 11:41 AM
jdsmoothie's Avatar
Quoted: 15360 Post(s)
Liked: 7508
Check the Owner's manual and try resetting the microprocessor.
jdsmoothie is offline
post #3 of 18 Old 10-31-2013, 11:52 AM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Has the "MUTING" function (pg. 22 of the owner's manual (PDF)) accidentally been activated?
eljaycanuck is offline
post #4 of 18 Old 10-31-2013, 02:09 PM - Thread Starter
A240494's Avatar
Micro-processor was reset. also was told that the mute would cancel when turned off and on also that it would show in front panel mute. Do not have remote. that is a whole other story, for now just trying to get it to work.. Thanks guys!
A240494 is offline
post #5 of 18 Old 10-31-2013, 02:14 PM - Thread Starter
A240494's Avatar
Tried did not work. Thought the mute might be on. but was told that if so it would show in the display. Thank you for your reply..
A240494 is offline
post #6 of 18 Old 10-31-2013, 03:13 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
what happens when you plug in your headphones... does the rcvr display show that "action". IF not, that means it "thinks" that the headphones are already plugged in and therefore the speaker outputs are shut down.
further what is the receiver display showing for output configuration in terms of speakers???
budwich is offline
post #7 of 18 Old 10-31-2013, 04:38 PM - Thread Starter
A240494's Avatar
When the headphones were plugged in, the display showed this and when the headphones are unplugged the correct speaker configuration is displayed both when surround speakers are plugged in and when just the fronts are.
A240494 is offline
post #8 of 18 Old 10-31-2013, 05:03 PM
jdsmoothie's Avatar
Liked: 7508
Try doing the microprocessor reset at least 3-4 times in a row.
post #9 of 18 Old 10-31-2013, 09:22 PM - Thread Starter
A240494's Avatar
Done still no output, even got it to read optical in, still nothing.
A240494 is offline
post #10 of 18 Old 11-01-2013, 10:51 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
did you actually check the fuses with a meter... "seem ok" sounds like "your eyes"... only superhumans can see electrons...:-)
Further, when you plug in your headphones do you actually get any sound out of them???
A240494 likes this.
budwich is offline
post #11 of 18 Old 11-01-2013, 04:12 PM
jdsmoothie's Avatar
Liked: 7508
Sounds like it's time to consider something more current.
post #12 of 18 Old 11-01-2013, 07:27 PM - Thread Starter
A240494's Avatar
No haven't checked fuses with meter, where would I find the correct setting, And no sound out of the headphone, though the system does recognize that the headphone is plunged in, I will have the fuses checked tomorrow. Thank you and everyone for all your help, and sticking it out with me.
A240494 is offline
post #13 of 18 Old 11-01-2013, 07:58 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
you might want to enlighten us with a brief short history of the unit.... how long have you had it, has it ever worked, when did it stop, etc. Use the resistance setting on a normal multimeter with the receiver turned off and unplugged.
No sound from the headphones doesn't sound good. How about when using the tuner input even not tuned to a station (ie. noise / static).
Anyways, the more details you provide about things, the greater chance you have that someone might be able to help.... but at this point it doesn't sound good.... :-(
budwich is offline
post #14 of 18 Old 11-02-2013, 07:31 AM - Thread Starter
A240494's Avatar
I purchased  this used, I did test it as far as it powering up, warming up,  I know lesson learned here it before buying. I was wondering I have a Harmon Kardon and I had the same problem until I set it up with the remote and configured the input. since the remote is needed to manually set the FM stations, and I don't have the remote. the only thing I have to test is the CD, could it be a configuration issue?
A240494 is offline
post #15 of 18 Old 11-02-2013, 07:33 AM
jdsmoothie's Avatar
Liked: 7508
Resetting the microprocessor would return all settings to mfr defaults which would result in "plug-n-play" based labels on the input jacks.
post #16 of 18 Old 11-02-2013, 09:44 AM - Thread Starter
A240494's Avatar
Thank you for the links, I will call the number and let you know the results. What a great forum!
A240494 is offline
post #17 of 18 Old 11-02-2013, 10:36 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
Now we know the rest of the story. You would help yourself by finding and following a user guide for the unit. Most units have some way of doing things thru the front panel.
Anyways, It is more than likely the unit works fine but that you have not done anything to set it up.
budwich is offline
post #18 of 18 Old 11-03-2013, 05:22 AM - Thread Starter
A240494's Avatar
Update, after resting, in FM mode and after seting chanle volume to max I get FM, but volume control is not working, Qestion, does this mean that system is OK and I still need to work on set up. would having the remote to access on screen set up?
A240494 is offline
Denon Avr 2802 6 1 Channel Surround Sound A V Receiver
