Anthem MRX Receivers - 310, 510, 710 Owners Thread & Tweaking Guide - Page 123 - AVS | Home Theater Discussions And Reviews
post #3661 of 3665 Old 03-02-2015, 03:58 PM
Ejs71's Avatar
Quoted: 22 Post(s)
Hi all.
I've combed through this looking for a recent solution to my problem.
I have a MRX510 I just picked up. I'm trying to use ARC, and it doesn't work.
Just to let everyone how I have it set.
SYSTEM INFO:
Release and Main Micro Version: 1.2.6
Network Type: Wired LAN
IP Config: Mode: Auto
(greyed out) IP, Subnet Mask, Gateway
Ethernet cable hoooked from back of MRX to Airport Extreme Router/backupdrive
Using MAcbook Pro with VMWare fusion running Windows 8
I have setup.exe on desktop on Windows 8, and I double click it, and it installs and when the ARC 2 opens it scans for devices, and none are found. I am 100% my router is working, and the settings are as listed above on the Receiver.
Does anyone have any advice? I was so excited to get this receiver and the ACR is a dud. Really disappointed. I may not have even bough it in the first place if I new you HAD to have windows to use ARC.
Ejs71 is offline
post #3662 of 3665 Old 03-02-2015, 06:19 PM
drhankz's Avatar
Quoted: 37 Post(s)
Liked: 52
Originally Posted by Ejs71 View Post
Hi all.
SYSTEM INFO:
Check your SERIAL PORT # - It must be in a range of 1-7
drhankz is offline
post #3663 of 3665 Old 03-03-2015, 12:02 AM
MitchPope's Avatar
Hi all.
SYSTEM INFO:
I found this, but it was for Parallels, not VMWare, so maybe it is called something else:
-Bootcamp be damned! ARC works fine on Win 7 in Parallels on my Macbook Pro. I needed to change the "Network mode" from "Shared" to "Bridged" and that's it... no issues connecting to USB mic or MRX over Wifi. Piece of cake.
The Serial/COM Port 1-6 was for the previous model, part of what made the x10 series that much better to deal with.
MitchPope is offline
post #3664 of 3665 Old 03-03-2015, 01:21 AM
mazpri's Avatar
Quoted: 38 Post(s)
Liked: 24
I use a MacBook with Bootcamp and Win7 and there is no probs whatsoever. I guess you have a network config problem using the virtual machine AND most likely with DHCP setup of the router. I don't know how airports are configured, but the MRX shows a IP address in setup menu when DHCP did work. Make sure you see the MRX in the router to begin with, in DHCP config listings for instance, or with any other network device, don't know if the MRX would answer a ping since I never had issues connecting - not counting loose network cables...
But it does post a host name (netbios type afaik) for sure.
mazpri is offline
post #3665 of 3665 Old Today, 09:39 AM
noninoni's Avatar
Liked: 0
Guys I really need help - despite reading various help links at the begining of this thread.
I upgraded from mrx700 to 710 and bought two REL S5 subs that should radio linked (Longbow).
I understand that both subs will work as dual mono.
How on earth do I start the setup if I really cannot alter the positioning ( both subs pointing forward on the inside of both main front speakers) ?
When I switch the mrx on do I try fiddling with the sound of each sub separately , then run them both to fix phase, and then run arc ?
Any advice on settings?
I have no local dealers for either make and had to buy from abroad so I have nobody to talk to.
Please do let me know any hints, tips or tricks to get this right.
Many thanks
noninoni is online now
Anthem Mrx710 , Anthem Mrx510 , Anthem Mrx310
Gear in this thread - Mrx710 by PriceGrabber.com
