Anthem MRX Receivers - 310, 510, 710 Owners Thread & Tweaking Guide - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 295Likes
post #4741 of 4744 Old 09-23-2016, 01:04 PM
maestreaux's Avatar
Quoted: 75 Post(s)
Does anyone else have constant Anynet connection problems with your Anthem and Samsung TV? I have a 710 and a 65" JS8500. It will work beautifully for a few weeks and then all of sudden nothing? No connection between the two, no device found. After a few weeks of no connection all of sudden they start connecting again. The cycle has been continuous for a about a year.
maestreaux is offline
post #4742 of 4744 Old Today, 08:30 AM
ebr9999's Avatar
Quoted: 55 Post(s)
Originally Posted by techguy378 View Post
My sub is a SVSound PC12-NSD cylinder sub. ARC sets the trim level at +0.5db. ARC sets both front left and rights at - 1db and the center channel at +4db. The center channel is behind the TV which is sitting on top of the fireplace. Unfortunately I can't put the center in front of the TV because of the way Samsung's stand curves out on their 8500 series plasmas. No room. ARC does play several test tones on each speaker during the first sweep.
I guess that the route cause is in your center ... You can verify it by trying a measurement set without center channel (i.e. 2.1 configuration) - If I am right it should work without any warning messages and front and sub should have similar trimming levels.
How does it sound with movies dialogue (in case of multi-channel)?
Media Server Audio: Teufel Connector 2 Media Server Video: XBMC TV: Panasonic TX-L37ET5E BD/DVR:Panasonic BMR-BWT735 Media player: Teufel Connector 2, WD TV Live (Remoto/cucina), HT Rec: ANTHEM MRX 510, Front: Woofer & Tweeter, Center: 2 Woofer & Tweeter, Surround: Bose acoustimass 5 series II, Sub: SVS SB2000
ebr9999 is offline
post #4743 of 4744 Old Today, 03:21 PM
techguy378's Avatar
Quoted: 23 Post(s)
It sounds overly bright like movie theater sound. Strange thing is I reran ARC last night. This time it was able to calibrate to 75db. I ran it a few times to make sure I wasn't doing anything wrong. This time the center channel trim level was set to +8db instead of +4. The fronts were both set to +3db and the sub was set to +3db instead of +0.5db. The sound is noticeably improved too. It doesn't sound overly bright like it did before. Just seems strange that the ARC results are drastically different after running from the exact same measurement positions.
techguy378 is online now
post #4744 of 4744 Old Today, 06:31 PM
Apgood's Avatar
Quoted: 63 Post(s)
Liked: 27
Even very small changes in the orientation of the microphone can have impacts on readings of the upper frequencies, so it might well be that previously something was causing the upper frequencies to read lower than they actually are, so ARC was applying cuts to the bass to compensate.
Apgood is online now
Anthem Mrx710 , Anthem Mrx510 , Anthem Mrx310
