Anthem MRX Receivers - 310, 510, 710 Owners Thread & Tweaking Guide - Page 164 - AVS Forum | Home Theater Discussions And Reviews
 308Likes
post #4891 of 4892 Unread Today, 06:25 AM
Liked: 0
Originally Posted by mazpri View Post
Hi Indy. Odd to see your surrounds perform better at 100Hz an below than your fronts n center. In case these should be performing same sth is wrong. Redo the setup using QuickMeasure to position and toe in the correct angle of your speakers. Leave one setting to all auto to start with and for comparison of manual settings. Setting no.1 looks messed up alot, subwoofer at 300-700Hz? These Tannoys can't do 80Hz crossover.
Afaik the firmware has changed some things and is recommended for latest ARC PC software, the downloads include a version history. I recommend to use the latest ones only, both firmware and ARC software.
This is for the latest firmware:
HI Mazpri, yeah it's very annoying why the Fronts and center are not as good as rears. I have been told that the speakers aren't powerful enough, not sure if this is because I'm about 9 feet away from them and I'm pretty close to surrounds.
I've been recommended to buy the KEF LS50's and a BK Subwoofer, I have just got the new sub, BK XLS200, which sounds amazing, go the super spikes to go with it and very happy with it as bass wasn't very good for music on the Tannoy sub.
I have went down to 5.1 and tried messing about with front speakers but can't get a good response at all, still sound ok but I know it can sound a lot better. I'm currently saving up for the KEF's, do you think they will help?
Indy
Indiana Bones is offline
post #4892 of 4892 Unread Today, 10:44 AM
mazpri's Avatar
Quoted: 120 Post(s)
Liked: 46
Originally Posted by Indiana Bones View Post
I have went down to 5.1 and tried messing about with front speakers but can't get a good response at all, still sound ok but I know it can sound a lot better. I'm currently saving up for the KEF's, do you think they will helpy
Don't know, i'm not so much into KEF. I really would try to fix the given setup using an updated firmware and ARC software using the auto settings then.
In case the fronts and rears of that speaker set are same build you also can swap those to see if things change. In case the speakers show same measurement when doing Quick Measure each speaker in ARC software from roughly 3ft mic distance you can blame it on the room layout. I'd put the better ones to the front in case there are any differences.
I'm pretty sure your sub and satellite combo does the job when not broken - and it's a given, there are always better and/or more expensive speakers to find, but that goes way off topic...
mazpri is online now
Anthem Mrx710 , Anthem Mrx510 , Anthem Mrx310
