Buying my first receiver. What 5.1 receiver to get below $350? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-02-2013, 04:33 PM - Thread Starter
lettuceman44's Avatar
Hey guys, I'm making my first HT system. It will be a 5.1 system composed of Pioneer BS22s for front and surrounds(or FS52 for the fronts, haven't decided yet), Pioneer C22 for the center, and a Dayton Sub1200 for the sub. These will be the parts I will be using.
So now I need to come up with a receiver. I gave myself a price point of $350. So that means I'm looking at the Denon AVR1613, Denon E300, and the Yamaha RX-V375.
I could really care less about networking. All I want is the best sound quality for movies, and a good on screen display. For inputs, I only need 4 hdmi, which all the lower end receivers seem to have.
Any suggestions on receivers? Really I want to go as "cheap" as possible without sacrificing quality. So bang for the buck is important to me.
lettuceman44 is offline
post #2 of 13 Old 11-02-2013, 04:55 PM
mj79's Avatar
Have you checked accessories4less? They are all refurbished with warranty, and could get a heck of a deal. Very reputable site and highly recommended here.. Great CS as well.
Here's the 1613 you were looking at.
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html
Also let's you get into a much higher end receiver for the same $350 if you wanted to go that route too
mj79 is offline
post #3 of 13 Old 11-02-2013, 04:59 PM
mj79's Avatar
If I were you I would look at this one as well.
Little more than you wanted to spend but great sq from what I hear.
http://www.accessories4less.com/make-a-store/item/ONKTXNR626/ONKYO-TX-NR626-7.2-Ch-Network-A/V-Receiver/1.html
Hopinater likes this.
mj79 is offline
post #4 of 13 Old 11-02-2013, 05:34 PM
Hopinater's Avatar
Quoted: 1784 Post(s)
Liked: 4394
If its worth anything I agree with mj79. I didn't know about this site but it has some great deals. Good to know about the cs as well. Thanks mj.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #5 of 13 Old 11-02-2013, 05:35 PM
Quoted: 73 Post(s)
Liked: 112
I like Denon myself and they can certainly be found in this price range.
rnatalli is offline
post #6 of 13 Old 11-02-2013, 05:54 PM - Thread Starter
I did look at A4L, but refurbished units scare me.
Do I have unfounded worries?
Sent from my HTC One using Tapatalk
post #7 of 13 Old 11-02-2013, 07:40 PM
jdsmoothie's Avatar
Quoted: 12126 Post(s)
Liked: 5522
Generally a solid choice, although unfortunately there are going to be some bad apples in the bunch.
jdsmoothie is online now
post #8 of 13 Old 11-02-2013, 08:39 PM
mj79's Avatar
There are bad apples with brand new unboxed units as well....
OP I wouldn't be one bit worried about refurbished... Just curious.. Why are you worried? they are refurbished at the respective factory, and carry at least a 1 year warranty.. According to the members on here, the products look like new once received...
mj79 is offline
post #9 of 13 Old 11-02-2013, 09:56 PM - Thread Starter
I've read some comments on here about bad Denon units, but looking at the return policy and warranty, you are right. Why not.
So yea, I'll go with a refurb unit for sure.
Hmm now to choose a receiver.
post #10 of 13 Old 11-04-2013, 01:20 PM - Thread Starter
I have a question about Yamaha and YPAO. I know there receivers are well regarded, and really the only reason I was going to get a Denon was for Audyssey.
How is YPAO vs Audessy? Should I consider that, or if I find a good deal on a Yamaha just go with that?
Reason I ask is because I've already seen a few deals on Yamaha.
post #11 of 13 Old 11-04-2013, 05:35 PM
jdsmoothie's Avatar
Liked: 5522
With the lower/mid level models, the version of YPAO used does not EQ the subwoofer, while all Denon models that feature Audyssey can EQ both the speakers and the sub.
post #12 of 13 Old 11-04-2013, 06:36 PM
mj79's Avatar
I was curious about ypao as well. Now that I paid $400 for my Sony dn840, the Yamaha 773 and denon x2000 are really making me think about returning it...
mj79 is offline
post #13 of 13 Old 11-06-2013, 04:27 PM - Thread Starter
How do you know the version of YPAO?
Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Pioneer Andrew Jones Sp C22 Center Channel Speaker , Dayton Audio Sub 1200 12 120 Watt Powered Subwoofer , Denon Avr E300 , Yamaha Rx V375 5 1 Channel Av Receiver , Denon Avr 1613 Receiver , Sony Str Dn840 , Yamaha Rx V773wa Receiver , Denon Avr X2000 7 1 Channel Home Theater Receiver
