Denon x2000 issues with "This is the End" Blu-Ray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-03-2013, 09:24 AM - Thread Starter
Hotscot's Avatar
Was playing the "This is the End" Blur-ray last night.
Sony player, Denon AVR X2000, Panasonic plasma.
On several occasions throughout the movie the screen went blank and therefore it became unwatchable. We gave up.
This morning I plugged the player directly into the plasma and it displays fine with no breakup.
If the problem is a setting in the amp are there any pointers where I should look?
Could it have been the HDMI cable itself? (I've still to try further swapping/testing.
Hotscot is offline
post #2 of 4 Old 11-03-2013, 09:34 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Hotscot, you could try turning off Deep Color Output on the BD player before replacing the HDMI cable.
JChin is offline
post #3 of 4 Old 11-03-2013, 10:01 AM - Thread Starter
Hotscot's Avatar
Thanks. I'll try and report back.
Hotscot is offline
post #4 of 4 Old 11-03-2013, 10:31 AM - Thread Starter
Hotscot's Avatar
Switched off Deep Color Output but no effect. Swapping cables next to at least eliminate those.
Update: Software update for Sony player. Problem fixed. Guess it was a known issue.
Hotscot is offline
Denon Avr X2000 7 1 Channel Home Theater Receiver
