Is my receiver (Marantz NR1603) powerful enought for floor speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-03-2013, 06:34 PM - Thread Starter
Harry Muscle's Avatar
I'm gonna be setting up a new living room home theatre and due to space constraints was hoping to get a half height receiver. My current choice is the Marantz NR1603 which provides 50W of power to each channel. I was hoping to match this up with 4 Pioneer SP-FS52 floor standing speakers (specs: http://www.pioneerelectronics.ca/ephox/StaticFiles/PUSA/Files/Home/Andrew%20SP-FS52Single%20Sheet.pdf) and the Pioneer SP-C22 center channel speaker (the backs will be floor standing also cause the price for the bookshelf speakers with stands is the same as the floor standing speakers). The question I have is whether the 50W per channel will be enough to drive these floor speakers to moderate (or the low end of loud) levels?
Harry
Harry Muscle is offline
post #2 of 7 Old 11-03-2013, 06:47 PM
jdsmoothie's Avatar
Quoted: 15354 Post(s)
Liked: 7508
Lower end of moderate volume likely, but much above moderate would be iffy as they are only 6-ohm and not very efficient speakers.
jdsmoothie is online now
post #3 of 7 Old 11-03-2013, 06:56 PM
kbeam418's Avatar
Location: 41.7080574, -83.5911255 N41° 42.4834', W083° 35.4675'
Liked: 47
Harry
Depends how far you're sitting from the speakers. I use about .001 watts for my listening sessions; but my speakers have a 97 dB sensitivity and I only sit about 4 1/2 feet away from them.
"Then one day you find ten years have got behind you no one told when to run you missed the starting gun."
kbeam418 is offline
post #4 of 7 Old 11-03-2013, 08:34 PM - Thread Starter
Would it make more sense to use this receiver with the bookshelf speakers instead? (SP-BS22-LR - specs: http://www.pioneerelectronics.ca/ephox/StaticFiles/PUSA/Files/Home/Andrew%20SP-BS22-LRSingle%20Sheet.pdf)
Harry
P.S. Alternatively, are they other speakers I should be considering? Based on my research these seem to be the best you can get for that price range ($150 each for floor speakers).
post #5 of 7 Old 11-03-2013, 08:51 PM
kbeam418's Avatar
Liked: 47
Harry
Are you able to take a listen to these speakers before buying them? Based on the specs I would say the towers will perform better but specs can be misleading. They both have the about the same sensitivity so other than that there's no advantage of the bookshelf speakers. How about these? http://www.amazon.com/Klipsch-Synergy-F-20-6-5-Inch-Floor-Standing/dp/B003XRD9TQ/ref=zg_bs_3236453011_32 They are only $19 more and they have better specs, plus have a 95 dB sensitivity so it would be much easier on your amp.
kbeam418 is offline
post #6 of 7 Old 11-03-2013, 09:01 PM
kbeam418's Avatar
Liked: 47
The receiver will be putting out a little more than 50 watts since these speakers are 6 ohms.
kbeam418 is offline
post #7 of 7 Old 11-03-2013, 09:35 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
Harry
The tower speakers are 87db efficient - the bookshelf speakers are less efficient at 85db (typical of bookshelf speakers) and take more power to achieve the same sound levels. The best way to set this system up would be to add a sub if you don't already have one and set the crossovers to 80 or 100hz. This takes a lot of pressure away from the receiver since it doesn't have to reproduce the lower frequencies. Low frequencies take more power to reproduce than the higher frequencies. Since the sub has its own power amp it reproduces most of the sounds from 80-100hz and lower. Unless you want to make your ears bleed you should be fine with the 1603 AVR.
If you do not plan on adding a sub then a more stout receiver might be a better option.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
Marantz Nr1603 Slim Line Av Receiver
