Pioneer VSX-1023-k Won't wake from Network, also pink screen every now and then. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-04-2013, 02:36 PM - Thread Starter
Herecomes2's Avatar
Hello, I recently purchased this great receiver but I have two issues I'm hoping someone can help me with.
1) Using Airplay I should be able to wake the receiver through the network. I had a 823k and it worked with moderate success, With this 1023-k it doesn't seem to work at all. Airplay works fine when I manually turn the receiver on. "Wake from Network" is enabled. I've updated to the latest firmware. Any ideas what could be the issue?
2) Every now and then when I turn on my cable box, the image has a strong pink screen. I'm wondering if this is a known problem with HDMI? The problem isn't there if I run the HDMI straight from my tv to my receiver. But I'd like to keep the receiver as the central hub.
thank you for any help.
Herecomes2 is offline
Pioneer Channel Av Receiver Vsx 1023 K
