What settings does the SR806 remember after being switched/powered off? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-04-2013, 10:54 PM - Thread Starter
carsonlittle's Avatar
I adjusted and tuned the Onkyo SR806 for a few hours but am afraid to turn it off in case it "forgets" some settings if powered off.
What settings in the SR806 survive a power cycle?
Does it remember the Z2, Audyssey, Listening Preset settings even after being powered off?
carsonlittle is offline
post #2 of 4 Old 11-04-2013, 11:17 PM
Knucklehead90's Avatar
Quoted: 495 Post(s)
Liked: 423
Unless there is a malfunction in the memory section - yes - it will remember the settings from running Audyssey and user settings as well. It may not remember you switched from 5.1 to 2.1 music but thats easy enough to turn back on.
carsonlittle likes this.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 4 Old 11-05-2013, 12:33 AM - Thread Starter
The power draw of this unit seems to be 60W when idle!
BTW: Does the Audyssey setup try the subwoofer too? After the Audyssey setup, I noticed that it had turned LFE off and I did not hear any sounds off the subwoofer during the calibration process
post #4 of 4 Old 11-05-2013, 07:33 PM
Quoted: 495 Post(s)
Liked: 423
You might want to make sure the subwoofer is on during Audyssey setup. It should detect it during the setup process. It is possible to remove the subwoofer in the manual setup menu. If that has been done the subwoofer may not be queried during the Audyssey setup.
Onkyo Tx Sr806 Receiver
