Cannot get Dolby True HD or DTS HD Master on X4000 - please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-05-2013, 11:00 AM - Thread Starter
Kevin_Roy's Avatar
Hi,
I just hooked up a Denon X4000. I have tried everything I can think of to get True HD and DTS HD recognized. I can get the old Dolby Digital and DTS through the receiver. I however, cannot get the Lossless formats.
Kevin
Kevin_Roy is offline
post #2 of 6 Old 11-05-2013, 11:05 AM
jontyrees's Avatar
Liked: 38
Originally Posted by Kevin_Roy View Post
Hi,
Kevin
What's the source? Could there be a choice in the menu of your BDP that's limiting you to the older formats? Also, make sure the True HD and DTS HD are on the BD you're playing. Might possibly be that the set up screens on the BD aren't in True HD, maybe once the movie starts they will be.
jontyrees is offline
post #3 of 6 Old 11-05-2013, 11:08 AM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 949
Doubtful it's a receiver issue. Try the owner's thread for whatever Blu-ray player you have. Make sure Secondary audio is turned off.
S~
We also ask that you use the owner's threads whenever possible.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #4 of 6 Old 11-05-2013, 11:12 AM - Thread Starter
Kevin_Roy's Avatar
Hi,
I have an Oppo BDP103. I have the HDMI audio output on there set to Auto. Everything source device are hooked up and set the same in terms of sources as they were on my Pioneer Elite SC-67. Thoughts?
post #5 of 6 Old 11-05-2013, 04:17 PM
kkpro's Avatar
Quoted: 116 Post(s)
Liked: 62
How are you hooked up to the receiver, HDMI or not? Which HDMI out of the OPPO, which one is selected as Main in the menu? Can also select bitstream in Oppo settings.
kkpro is offline
post #6 of 6 Old 11-05-2013, 04:24 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
eljaycanuck is offline
Oppo Bdp 103 3d Blu Ray Player , Pioneer Elite Sc 67 9 2 Channel Thx Select 2 Plus A V Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver
