Difference in volume levels for Onkyo TX-NR515 inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-06-2013, 04:45 PM - Thread Starter
Hoku68's Avatar
This probably is a really dumb question but is my first receiver.
Is there anything I can change or adjust so that the volume levels for different HDMI inputs aren't so drastically different?
For example "normal" volume for the cable box is high 20s,/low 30s, PS3 is 10, Bluray DVD is around 20. If not its definitely manageable, just an issue when switching for my daughter and wife.
Hoku68 is offline
post #2 of 2 Old 11-06-2013, 06:53 PM
jdsmoothie's Avatar
Quoted: 12318 Post(s)
Liked: 5622
There is a setting called "IntelliVolume" that you can set for each input source to normalize the volume levels between sources.
jdsmoothie is offline
Onkyo Tx Nr515
