Harmon Kardon AVR 146 for Polk monitor 75t - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-07-2013, 09:59 PM - Thread Starter
AVNOOOOOB's Avatar
  Hi all I am new to this forum and have done a good amount of research but I cannot find a direct answer to my question.  I just ordered a set of Polk 75t's. I hope they are good speakers.  I currently have a Harmon Kardon Avr 146 that I have barely used and a Sony SA-WM500 sub.  I am trying to set up a good 2.1 or maybe 3.1 surround mostly for watching movies and TV. Will my HK 146 be enough power and give me a good realistic surround sound ?  What do you gurus think of my setup for a newbie?
         Tom
AVNOOOOOB is offline
post #2 of 10 Old 11-07-2013, 10:29 PM
afrogt's Avatar
Quoted: 1444 Post(s)
Liked: 983
your receiver will be fine unless you've got a gymnasium sized room.
Afro GT
afrogt is offline
post #3 of 10 Old 11-07-2013, 10:55 PM - Thread Starter
AVNOOOOOB's Avatar
Thanks for the response. Will the audio work and soundgood with just hdmi or should I do it some other way.  I read that you had to use some other ay to get good audio.  Do you have any advice on how to set this up?
            Tom
post #4 of 10 Old 11-08-2013, 08:44 AM
afrogt's Avatar
Liked: 983
That's an older HDMI receiver which doesn't process HDMI audio. so you'll need to also connect an optical or digital coax cable for audio.
What devices are you going to be connecting to it?
Afro GT
afrogt is offline
post #5 of 10 Old 11-10-2013, 08:41 AM - Thread Starter
AVNOOOOOB's Avatar
It will be connected to my Laptop,Xbox and 55 inch Samsung  any suggestions on hooking everything up I was planning on using hdmi for everything.
                 Tom
post #6 of 10 Old 11-10-2013, 08:53 AM
afrogt's Avatar
Liked: 983
As long as your Xbox and laptop also have an optical out for audio you'll be fine. If not then connect those devices directly to the Samsung TV with HDMI and then run an optical cable from the Samsung TV to your HK receiver for audio.
Afro GT
afrogt is offline
post #7 of 10 Old 11-11-2013, 06:35 PM - Thread Starter
AVNOOOOOB's Avatar
Do you think the AVR146 will be enough to power the polks?
post #8 of 10 Old 11-11-2013, 11:15 PM
afrogt's Avatar
Liked: 983
You asked that in the first post, the answer hasn't changed....
Afro GT
afrogt is offline
post #9 of 10 Old 11-12-2013, 01:07 AM - Thread Starter
AVNOOOOOB's Avatar
Well I have been doing alot of reading and people say that the 75t's sound horrible when under powered
post #10 of 10 Old 11-12-2013, 02:55 AM
jproy13's Avatar
Liked: 26
Your receiver will be fine and will deliver all the power you need unless,as stated earlier, you are watching movies in a gymnasium.
Cheers
jproy13 is offline
Harman Kardon Avr 146 Home Theater Receiver With Ipod Control And Hdmi Connectivity
