Do I need to upgrade my Onkyo HT-R380 when I get new speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-15-2013, 04:06 PM - Thread Starter
ewitty's Avatar
So I've been running an Onkyo HT-R380 for about 2 years and using the speakers that came with the HTIB package for this system. They're ok but definitely not blowing me away or anything.
I've decided to upgrade to Polk Monitor 60 or 70 speakers (and accompanying center channel). I may or may not get a new subwoofer (the one that came with the Onkyo is passive and very very weak) but I'm not sure if I have to upgrade my receiver or not.
Any advice would be appreciated - sorry I'm a total newb and don't know many of the terms. If I need to buy a new receiver my budget is no more than $400 USD. It would be nice to have more than 3 HDMI inputs but I'm really not picky on features - I just want the new Polk speakers to sound awesome. Thanks!
ewitty is offline
post #2 of 8 Old 11-15-2013, 04:24 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
Polk speakers are fairly-efficient (meaning they don't need a lot of power to drive them to loud levels), 8-ohms (resistance) speakers. Your current AVR should have no trouble driving them.
eljaycanuck is offline
post #3 of 8 Old 11-15-2013, 04:35 PM - Thread Starter
ewitty's Avatar
Thanks! So I will only have to upgrade the receiver if I want to get a new subwoofer? Would there be any noticeable performance increase from upgrading the receiver now?
ewitty is offline
post #4 of 8 Old 11-15-2013, 05:51 PM
Knucklehead90's Avatar
Quoted: 384 Post(s)
Liked: 332
The biggest 'bang for the buck' in home audio is new speakers - not electronics. Lots of people say they hear a 'night and day' difference between their old AVR with and without that shiny new amp. It would have to be a very poor performing AVR to create that kind of 'night and day' difference. As for a subwoofer since your 380 doesn't have a subwoofer preamp out jack you'll need to find a subwoofer that has line level inputs - or a new AVR that has the proper preamp out for subs. Line level connections take the same connections that your speakers use. You run the wires from the L/R front speakers to the sub then more wires to your speakers. It is less than ideal and the LFE track on modern movie audio tracks is nearly useless to you but at least you get some decent low frequency sounds. Upgrading the AVR might be a good idea in your case.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #5 of 8 Old 11-15-2013, 06:15 PM - Thread Starter
ewitty's Avatar
Interesting, thanks a lot. It sounds like I don't want to invest in a subwoofer with line level inputs - better to get a new receiver and normal sub. Am I right?
How bad would it be to just upgrade the left/center/right speakers and leave the AVR and subwoofer as-is for now? I know that the bass won't be as good but my hope is that a passive sub + the low frequencies from the Monitor 70s might be sufficient. I expect a new AVR + sub would cost about $700-$800 and I'd rather save that money right now, but if it would be too ghetto then it would be nice to know upfront.
ewitty is offline
post #6 of 8 Old 11-15-2013, 07:05 PM
Quoted: 384 Post(s)
Liked: 332
You already have decided to buy those speakers connect them up and give it a try. You should hear a difference from those HTIB speakers.
I meant to say speaker level inputs for subs. Line level is the RCA jack connections - speaker level connect from the speaker outputs to the sub - then from the sub to the speakers. Many subs have both speaker level inputs and RCA (line level) inputs too so you'd be able to use it with any new AVR and have decent low frequency sounds. Your subwoofer is a passive sub - it has no amp - any AVR you buy won't be able to power it properly. Thats the trouble with HTIB setups - passive subs and 'different' speaker connections that often do not allow you to easily change speakers or subs.
***GO SEAHAWKS ***
post #7 of 8 Old 09-14-2014, 05:53 PM
Liked: 0
So this may be the biggest noob question ever. I have an Onkyo HT-R380 receiver. I fell into a pair of these Epos M12.2. I really want to hook them up but dont want to burn up my receiver or speakers if done incorrectly. I don't understand the 4 inputs on the back of the speaker and how I could hook it up to a receiver with only 2 outputs on the receiver for each speaker. If anyone could answer this question and help me up my sound game, I'd greatly appreciate it.
NoobAudioPhile is offline
post #8 of 8 Old 09-14-2014, 07:29 PM
Liked: 0
Bump
Bumping this thread looking for help!
