How will this work? - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2013, 05:45 PM - Thread Starter
tongr's Avatar
My TV (Sony XBR) can be set to output audio but still control volume. Can I hook up a two channel amp, not an integrated amp just an amp, to the TV via RCA and then hook two speakers to the amp for audio from the TV/satellite/BR player? As I said volume can be controlled by the TV. Will this work OK? I'm thinking of just going to a 2.1 system with high quality speakers.
tongr is offline
Old 11-20-2013, 05:52 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Sounds like it'll work just fine.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
Old 11-20-2013, 06:52 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Depends. If the source devices are connected via HDMI to the TV, make sure that the TV will output the HDMI audio via the analog outputs.
jdsmoothie is offline
Old 11-20-2013, 07:27 PM - Thread Starter
tongr's Avatar
Yeah, the satellite and BR player both run through the TV via HDMI. I know the TV outputs with this setup because I'm currently running some M-Audio monitors receiving RCA from the TV. I guess my biggest question is that there would be no "gain" control, just a volume control. I know the TV will increase and decrease volume but will it be ok with no gain control?
tongr is offline
Old 11-20-2013, 08:26 PM
Quoted: 385 Post(s)
Liked: 332
What is the difference between gain control and volume control?
***GO SEAHAWKS ***
Old 11-20-2013, 08:30 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
The technical definition differs but in practice they are the same. Both change the gain from input to output. Some use the terms interchangeably, and some define pads (attenuators) instead of volume controls. Not sure I have seen a real consensus on circuit definitions (I was weaned one way but many other techies have differing views).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 11-21-2013, 06:50 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
While they are the same, I think gain is more commonly used in pro audio and volume in home audio. I can't tell you why.
FMW is offline
Old 11-21-2013, 10:31 AM
DonH50's Avatar
Liked: 1325
Hmmm... I have done a fair amount of pro work and now that I think about it I think you are right. As to why, no idea. Maybe pros have no time to waste on two syllables when one will do. smile.gif IME "volume" has come to mean the final sound level, often a single control (one volume knob on the average consumer component), whilst "gain" is adjusted at many points along the sound reinforcement and/or recording chain (I have many gain controls from mic to speakers).
Old 11-21-2013, 11:10 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It might be a matter of simple word choices, or the gain control might be a simple attenuator while the volume control attempts to control perceived loudness which includes frequency response shaping.
arnyk is offline
Old 11-23-2013, 07:43 AM - Thread Starter
tongr's Avatar
My concern was if the amp has no gain control and is just pouring out full current if the TV volume control could handle it or if there would be problems ie. too loud too fast.
tongr is offline
Old 11-23-2013, 07:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Adding gain controls to a signal chain is pretty easy.
However, lots of people connect amps with no input gain controls to the line outputs if TVs that apply their volume control to them.
arnyk is offline
