RX-V375 is bivolt? - AVS Forum | Home Theater Discussions And Reviews
Old 11-21-2013, 08:27 AM - Thread Starter
rodrigobiz's Avatar
All Yamaha receivers are bi-volt, to be more specific the RX-V375 or RX-V475?
I need a 220v receiver, and kind difficult to find one here in Brazil...
Can I connect a subwoofer with sterio out in one of this two receivers without problem?
The product is this one:
http://www.jamo.com/images/common/SUB260/addl/SUB260_3.jpg
rodrigobiz is offline
Old 11-21-2013, 08:56 AM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1808
According to the owner's manual for the RX-V375, there are country- / continent-specific versions and there is a "General model" that appears to be dual-voltage. IMO, you should contact Yamaha Brazil - or one of their authorized distributors in Brazil - and find out where you can purchase either a 220V model or the "General mode".
eljaycanuck is offline
Old 11-21-2013, 11:42 AM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
Many, many AVRs are built in multi-voltage versions..
110V/120V/220V/230V...
However for the most part they are not sold through conventional retail channels in North America, as they are NOT UL/CSA certified..
Typically available through miltary exchanges, or tax-free export shops such as in Hong Kong and Singapore..
You can google and find these but shipping costs will surprise you so one needs a special connection..
Just my $0.05... 👍😉
rodrigobiz likes this.
M Code is online now
Yamaha Rx V375 5 1 Channel Av Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver
