Budget AVR w/HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-24-2013, 11:59 AM - Thread Starter
teleportgrend's Avatar
I have been using an all-in-one Pioneer unit that I purchased in 1985 to run sound from my TV through a pair of external speakers. I recently purchased a Samsung LCD that only has HDMI and component in, NO audio out, and there is a delay between the analog audio from my satellite box and the built in speakers on the TV. The external speakers are fine Klipschs (Okay, from the mid-90’s, but still working fine).
The room is not large, I am not looking for surround sound, it is just a spot for me to smoke a cigar and watch a movie. I figure it is time to upgrade the AV receiver, but I am a cheap SOB. Please correct me if I am wrong or offer advice.
1. If I pick up something with multiple HDMI inputs, and one out to the TV, I am assuming the sound from the external speakers will be a closer match. I have a new Blu-ray player and Directv that both utilize HDMI.
2. I am looking at Yamaha RX-V367 and HTR 3063. It looks like these are basically the same unit.
3. Is there a better option for under $200 that I should consider?
Thank you for your time and help!
-Mike
teleportgrend is offline
post #2 of 7 Old 11-24-2013, 12:51 PM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
You might prefer one of the newer Yamaha receivers with room calibration and a microphone like the RX-V375.
http://www.accessories4less.com/make-a-store/item/YAMRXV375BL/YAMAHA-RX-V375-5.1-Channel-AV-Receiver/1.html
Or an Onkyo with networking too. That way you can stream internet radio, Pandora, etc.
http://www.accessories4less.com/make-a-store/item/ONKTXNR414/Onkyo-TX-NR414-5.1-Home-Theater-3-D-Ready-Network-A/V-Receiver/1.html
Afro GT
afrogt is online now
post #3 of 7 Old 11-24-2013, 01:03 PM - Thread Starter
Thank you. Either of those would work. I am assuming I would need to pick up a WiFi dongle to connect the Onkyo w/my home Wifi.
post #4 of 7 Old 11-24-2013, 01:05 PM
afrogt's Avatar
Liked: 763
probably but I'd recommend running an ethernet connection directly to the receiver if at all possible.
Afro GT
post #5 of 7 Old 11-24-2013, 02:09 PM - Thread Starter
Does either the YAMAHA RX-V375 or Onkyo TX-NR414 stand out as a better (longevity) receiver? It might be another 25 years before I upgrade again.
post #6 of 7 Old 11-24-2013, 02:17 PM - Thread Starter
Opps. Double tap...
post #7 of 7 Old 11-24-2013, 02:20 PM - Thread Starter
Thanks for the link above. It's like a rabbit hole that goes on, and on, and on...
Now I am looking at sub $150 receivers.
Do any of the following stand out as either above the others or avoid by all means?
DENON AVR-1513
Onkyo HT-RC330
Onkyo TX-SR313
ONKYO HT-RC440
Yamaha Htr 3063bl 5 1 Channel 500 Watt Av Receiver Each Black , Yamaha Rx V367bl 500 Watt 5 1 Channel Av Receiver Each Black , Onkyo Tx Nr414 , Denon Avr 1513 Receiver , Onkyo Tx Sr313 5 1 Channel Home Theater A V Receiver Black
