Onkyo tx-nr 609 update firmware fail - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-24-2013, 11:07 PM - Thread Starter
usero's Avatar
Hello,
I have tried to update the firmware on my TX-NR609 but unfortunately, while it was 60-70% completed, the electrical power was shuted down so the firmware update was interupted.
Now all I can see is "onkyo" on my TV, and it stuck there.
I noticed that I can play music through USB, all the rest is broken..
It is anything that I can do to fix it?
usero is offline
post #2 of 5 Old 11-26-2013, 06:47 AM - Thread Starter
usero's Avatar
Not even one advice? It is possible that my receiver is permanently damaged? Even Onkyo support team can't help?
usero is offline
post #3 of 5 Old 11-26-2013, 09:27 AM - Thread Starter
usero's Avatar
I have tried several "reset", but the device still do not boot, the TV show me only "ONKYO" displayed there.
How can I enter the menu on the device screen using buttons?
I repeat, the USB is working, I can play music through it.
It is possible to enter firmware update menu without TV out? Only using device screen and buttons?
usero is offline
post #4 of 5 Old 11-27-2013, 07:08 AM - Thread Starter
usero's Avatar
Solved... But since nobody it is interested... I will leave this forum.
usero is offline
post #5 of 5 Old 11-15-2014, 11:00 PM
mrodrigues's Avatar
Post your solution. Sometimes you have to be the first person to put the information online. Someone will definitely be interested in this in the future, and will probably be upset that you decided not to share. You have the power to prevent others from suffering like you did.
mrodrigues is offline
Onkyo Tx Nr709 , Onkyo Tx Nr809 , Onkyo Tx Nr3009 , Onkyo Tx Nr5009 , Onkyo Tx Nr708 , Onkyo Tx Nr808 , Onkyo Tx Nr1008 , Onkyo Tx Nr807 , Onkyo Tx Nr414 , Onkyo Tx Nr906 , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver
