Where to buy Amplifiers; AVR's in Hong Kong? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-28-2013, 09:45 AM - Thread Starter
RefTheater's Avatar
I need to buy a Pioneer SC-LX90 (Susano) and in Hong Kong there are stores who still have them Brand New.
The voltage is the same as Europe, but i would like to know if there is a place where we can buy and is secure.
Tank you
RefTheater is offline
post #2 of 4 Old 11-28-2013, 12:01 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 493
In Hong Kong, there are many, many electronic stores located around Causeway Bay, Tsim Sha Tsui, Mong Kok and Sham Shui Po. However one should do his home work for pricing considering various exchange rates, also export models are available in multi-voltage and both PAL & NTSC formats. Be sure to double-check that all required accessories are included, frequently they will sell a unit @ a good price and then gouge the buyer for the accessories....
Additionally research about warranties, some are covered by global guarantees backed by up factory supported tech centers located in certain Euro countries.
Some brands/units are not covered...😡
There are some excellent buys but as mentioned above the buyer needs to do his homework before shopping!!
Final point, you should check if there are any significant tax duties as well when importing..
Just my $0.05.... 👍😉
M Code is offline
post #3 of 4 Old 11-28-2013, 12:42 PM - Thread Starter
RefTheater's Avatar
Tank you for the tips. They have online sites?
I talked to a friend who is also trying to get it in Macau.
post #4 of 4 Old 11-28-2013, 02:05 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 493
No..
They don't have websites.....
No experience with buying in Macau but the same basics apply:
1. Check pricing
2. Currency exchange rates
3. All accessories are included
4. Warranty..
M Code is offline
