Wireless Connecion for Pioneer VSX-1022 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-29-2013, 08:22 AM - Thread Starter
mrrkier's Avatar
Doe anyone know how to cost effectively connect the Pioneer VSX-1022 to a wireless router/modem?
mrrkier is offline
post #2 of 2 Old 12-05-2013, 05:12 PM
techie52's Avatar
Liked: 24
I used an old Linksys WRT-54G with Tomato firmware as a wireless bridge to connect my VSX-43; just got it working today with Airplay. I found my Linksys on the sidewalk in a rainstorm; you should be able to get one for a few dollars on Craigslist. Get V1 to V4; Tomato doesn't work with V5 or later. Wireless G bandwidth should be plenty for streaming.
See this thread for one problem I had and its solution.
If you can't find a WRT-54G I highly recommend the TP-Link TL-WR702N at $22 from Newegg. I have two of these functioning as a wireless bridge in my office and they have been rock-solid for almost a year now.
I know it's been a while since you posted your question but if you're still looking for a solution one of those might help.
Panasonic TCP55ST50
Panasonic DMP-BTD220
Pioneer Elite VSX-43
2X Bang & Olufsen Beovox S75
techie52 is offline
Pioneer Vsx 1022 K 560w 7 Channel A V Receiver
