The "Official" Onkyo TX-NR929 Owner's Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #631 of 656 Old 03-02-2015, 03:46 PM
Ckindt's Avatar
Liked: 35
Originally Posted by rsar View Post
What kind of additional amplifier do I need to utilize all of the 929 speaker outputs?
Simple answer: a 2-channel amp with unbalanced inputs at 50 - 100 watts/channel should suffice for most.
You only need it to drive your two front wides.
1 example
Onkyo TX-NR929/11.1 | Outlaw 7125 | Polk:  CSi A6 C | RTi A9 powered by qsc gx5  L&R | tsx110b Ht,Wd,SS and SB | Sub - Rythmik FV15HP | Samsung 60" UN60F8000BF | Samsung BD-F5900 | Theater Room
Ckindt is offline
post #632 of 656 Old 03-05-2015, 06:38 PM
rfb6435's Avatar
Quoted: 118 Post(s)
Liked: 50
1 example
It is nice that the 5010 is available new and will match nicely on an AV rack. I had an onkyo M282 which is basically just an older (and better) version of the 5010 for exactly this purpose but I sold it a few months ago.
The M282 is 100w/ch @ .08% THD, where the 5010 is only 75w/ch @ .08% THD all at 8 ohms. I see the 5010 available for $250 at a couple of places where the M282 should cost half of that used if you find the right deal.
Sonamp (260s/270) and Rotel (RB-960/RB-970) are also a great option for a cheap 2 channel amp in the 60w range used...
I decided that for the rack space I might aswell get a 5 channel amp that is designed for a 5.1 system to run WL, L, C, R, WR. The 5 channel amplifiers have similar footprints to the 100w/ch 2 channel amplifiers. Given that I needed an amplifier anyway to run 11.1 and this gets more heat out of the unit.
I find used Adcom amplifiers to be the best bang for the buck as you can see in my signature...
There are several good used options where you can get 5 channel 100w @ 8ohm amplifiers for $350 or less.
Examples of really good cheap 5 channel amplifiers include: Adcom GFA-7000 (135w), Adcom GFA-7400, Adcom GFA-7605 (really the same exact amp as the 7400 just rated at 1% THD in a new case), Adcom GFA-6000 (3x100, 2x60 but only $200 or so), Rotel RB-985 (either mkI or mkII).
For something flexible used the Rotel RMB-1066 and Rotel RB-976 are bridgeable 6 channel amplifiers that can run either 6x60W or 3x150W @ 8ohms.
-Rich
Marantz SR7009 Atmos 9.2.2 or 7.2.6 (scAtmos).
Adcom GFA-7500 150W/ch (WL/L/C/R/WR), Adcom GFA-7607 125W/ch (TMR/SR/SBR/SBL/SL/TML)
HTD L3 Tower L/R/C, HTD L2 Tower WL/WR, HTD Dual 12" Subs
HTD L2 Bookshelf SBL/SBR, HTD 6.5" Angled Ceiling FHL/FHR/SL/SR, HTD 8" Ceiling TML/TMR
Epson 5300ub 1080p 3D Projector with Monoprice 106" Multi-Format Screen.
rfb6435 is online now
post #633 of 656 Old 03-06-2015, 06:46 AM
ESSNEFF's Avatar
Quoted: 21 Post(s)
Liked: 7
1 example
I use a Crown X1000 for the Wides. 200W per channel. I Paid $99 for it. I could not detect a difference between my Emotiva XPA-5 and the Crown when running them on the Front speakers.
ESSNEFF is offline
post #634 of 656 Old 03-07-2015, 06:14 PM
CherylJosie's Avatar
Quoted: 680 Post(s)
Liked: 271
To get 11.1 audio you have to add a stereo amplifier. Without it the receiver only does 9.1. (the sub outputs are like a y connector and mono so the 929 should really have been called 9.1 not 9.2)
Just about any amplifier will do so if you have an existing vintage receiver with an adapter patch bay on the back for graphic EQ you can use the input half of that patch bay (you can also use the aux input if you leave the volume set to about 50% and disable tone and loudness and boost/cut filters), but if you want quality sound from the wides equal to what the rest of the channels are capable of you should plan on a receiver or integrated stereo amp that will output ~130WPC into 8 ohms.
Note that the center speaker will be doing most of the work so you can probably get by with less wattage on the wides but if you have to buy new you should probably match the capability of the receiver anyway.
Only 3 titles were released in Neo:x encoding so the only advantage of the wide or height speakers in Neo:x decoding with this receiver is in 'upmixing' for ambiance extraction. DSX does something similar but seems not to work very well IMO, probably because it tries to simulate reflections of a large room rather than just working with the program ambiance.
Speaker placement is critical. Your wides need to be right between your front mains and side surrounds, along the side walls and at the same height as the front mains or only slightly higher.
Your heights should be in/on the ceiling directly above the center of the room and spaced left to right about the same l/r separation as your left/right mains. If not in/on the ceiling then maybe try separating them more to the l/r and placing in the edge between side wall and ceiling.
Typical instructions place the heights as high up as possible on the front wall or in other words in the edge between front wall and ceiling. IMO this does not give them enough separation from the front l/r mains and reduces their imaging. They need to be closer to the front-to-back center of the room and preferably in/on the ceiling so that they sound like they are coming from directly overhead. If they are in the center of the room front-to-back they also occupy the space between the wides and side surrounds and that helps add separation by maximizing their distance to all other channels.
Note that deviating from the typical instructions (front wall as high as possible) as I suggested will make the 'screeen centered dialog' function add center channel to the mains and also to the heights that are directly overhead. That might sound odd with center channel dialog directly overhead, but IME 'screen centered dialog' sounds oddly monoaural anyway. I only use it for dialog intelligibility at very low volumes.
If you position any of the speakers in odd places you may find the imaging is not good due to speakers being too close to each other and not hearing any separation between them. The more speakers there are in a room, the more critical it is to ensure they all have maximally distant angular separation from each other as measured from the main listening position. My recommendation to put the heights overhead in line with the l/r mains maximizes the separation and that gives the most pleasing result with Neo:x upmix IMO.
Remember, if you are using Dynamic EQ for listening substantially below reference (-15dB or lower) you might want to adjust the side/rear surround levels down about 2dB, or if you have run out of downward adjustment range like me you can increase all the other non-subwoofer levels up about 2dB instead. Dynamic EQ applies more level boost to the surrounds the lower the volume control is set and IMO it makes the image sound unnaturally 'inside the head' like listening through headphones, with almost no front-to-back depth at all, particularly with surround music. Reducing the relative output of the surrounds restores the natural front-to-back balance. THX Loudness Plus (configurable in the setup menu) also increases surround level at lower volumes but the change is so subtle it is hardly noticeable.
CherylJosie is offline
post #635 of 656 Old 03-11-2015, 01:40 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
Had my new 929 since Nov, I noticed that just in the past couple weeks it sounds like there is a rely click randomly when the AVR is on. This is with the same source with same audio codec. Just clicks sometimes. Wonder why?
Goatse is offline
post #636 of 656 Old 04-08-2015, 07:15 PM
Quoted: 680 Post(s)
Liked: 271
Onkyo receivers only enable speakers that exist in the sound mode. Even though I have 11.1 setup it still makes these clicks when the sound mode changes the number of speakers that are active.
Additionally, some Onkyo receivers have more speaker output terminals than amplifiers so that you can install more speakers than exist in your available sound modes e.g. 929 without external amp has front high, front wide, rear surround available but only two of the three may be used simultaneously because there are only 9.1 amps in the receiver so the receiver has to switch the speaker outputs on the amps in order to use all of the speakers in their various mutually exclusive sound modes.
You can eliminate these clicks but it is a painstaking process. You have two choices. You can either specify via the colored buttons a single synthesized sound mode for each input stream (such as Neo:x or PLIIx-DSX) that uses all available speakers without re-mapping the speaker connections, and let the 'last valid' mode control the sound mode, or you can go into the setup menu, override 'last valid', and specify the same synthesized sound mode for every input format there. You can specify by physical input and by input format since every physical input has a sound mode for each input format i.e. analog, dolby digital, dts etc.
If you use the native sound mode for every input stream, or you select different sound modes for different input streams, you will hear clicking every time the stream changes, such as when the DVD or Blu Ray starts in stereo on the menu and switches to surround in the movie, or when a commercial comes on in stereo in the middle of a surround TV program, etc.
post #637 of 656 Old 04-08-2015, 07:18 PM
Quoted: 680 Post(s)
Liked: 271
Anybody know what the network chip defect issue causes for symptoms?
Does it cause momentary black-out of the screen and loss of audio for no apparent reason?
Does it happen even with networking disabled?
Does it cause flickering on component input color/intensity?
Does it cause momentary bursts of video noise when switching between video formats on component input?
Trying to diagnose if it is my components or my receiver... but no real frame of reference to check against. Anyone have it repaired already? What were your symptoms?
post #638 of 656 Old 05-16-2015, 08:19 AM
Carat_EST's Avatar
Liked: 1
Hi
On my TX-NR929 I somehow changed something in Setup - Picture Adjust for HDMI5 such a way (some kind of Standard position) that only blue screen is seen (480p resolution) without possibility to return any more to the Home Setup screen as needed (only the blue one). For other inputs the Receiver - Home - Setup works still.
How I can set this Standard back to Custom again?
BR
Lauri
Carat_EST is offline
post #639 of 656 Old 06-10-2015, 12:32 PM
Liked: 0
Having an issue with my receiver this morning. I have all my sound going through to my tv speaker for all my components. As far as I know nothing has changed with my setup but now the only sound from the tv I can get is the tv itself and its built in menus. Nothing from any of my components.
I've looked through the menus and things seem unchanged. Is there anything else I can check or something I might be missing?
Naetalis is offline
post #640 of 656 Old 06-10-2015, 12:53 PM
Liked: 0
Just another quick note that whichever source I choose to simply pass through when the unit is on standby/off, works just fine. Just when the receiver is on is it stopping any audio going through even though everything is set to tv speaker!
Naetalis is offline
post #641 of 656 Old 08-01-2015, 11:33 PM
Quoted: 680 Post(s)
Liked: 271
What is Phase Matching Bass and should I use it?
Might be useful to you 929 owners.
post #642 of 656 Old 08-24-2015, 08:47 AM
eieio's Avatar
Android App: how to bring up "menu" due to floating menu button gone?
Dear All:
i've used the Onkyo Android app for years and it's alright, of course much better than not having an Android app!
that said, i was prompted by the app that a new Onkyo app was available and i tried it, it was worse for me, often disconnecting (like every other day) and requires a power unplug of the Model AVR TX-NR929 in order for the new Onkyo app to reconnect.
so i was frustrated, and i decided to start using the OLDER Onkyo app (now named 2.3 on the app icon) again. however, the floating menu button has disappeared and i can't get it back. typically, almost all apps have a "3 dashes" on the upper left or right corner to bring up that particular app's menu. NOT ONKYO's app! poor design, however, one must live with what is available.
all current mobile phones no longer have a dedicated menu button anymore, so i'm truly stuck, now that the floating Onkyo menu button is gone.
may i ask how to bring up the menu button please? thanks in advance.
eieio is offline
post #643 of 656 Old 10-24-2015, 12:42 PM
Quoted: 122 Post(s)
Liked: 103
Zone 2 - digital source possible?
Hello,
I have gone through the manual and also some webpages, however, I didn't figure out a way yet to achieve the following.
Let's say I am using my HT with seven channels (bi-amping front), that leaves two channels for zone two.
I have wired the house so that my lady can enjoy her TV shows in the HT and I still can comfortably sit in my office listening to music - which ideally should be coming from my NR929 through the zone two.
Even more ideally, I connect my iPad to the appleTV, stream spotify music I want and listen to that - BUUUUT - this does not work. Zone 2 is only supported for analog sources, at least according to my research.
My question now: is there any way around it, any setting I can adjust, any update I need to make to make this happen: streaming zone two through my appleTV?
Thank you!
Kevin Grimm is offline
post #644 of 656 Old 11-14-2015, 02:52 PM
Liked: 0
Originally Posted by Kevin Grimm View Post
Hello,
Thank you!
Im in the same boat here. Just bought a new pair of speakers to extend the music in my house.
929 does support Zone2 via HDMI it seems, but really really low on full Zone2 volume.
From the manual:
ZONE 2 LINE OUT and ZONE 2 L/R output 2ch PCM,
analog, NET or USB input sources. To listen to the PCM
source, you need to make an HDMI connection.
What kind of outputs do your apple TV have?
silvrblue is offline
post #645 of 656 Old 12-14-2015, 02:26 PM
johnovox's Avatar
Quoted: 24 Post(s)
I have had the 929 for over a year and this is the exact issue I am now dealing with. The screen goes black and the audio stops; the video signal then returns without any audio. It happens regularly but just started a week ago. Any idea if this can be cured by having Onkyo service the "network chip defect"?
johnovox is offline
post #646 of 656 Old 02-03-2016, 05:09 PM
Quoted: 14 Post(s)
Liked: 0
Originally Posted by maids View Post
Can anyone help with settings. need setup for dummies
when we play from our PC we have to have the volume up to 80+ then if we switch to TV we get blown out the window.
Can someone tell me how to fix this?
Also our room is around 11x16 but is also open plan eg kitchen and dinning behind our listening area.
We keep cycling through the sounds when watching movies as sometimes the voices sound muffled.
When trying to adjust the volume I have pressed the tv button and can adjust the DB and the same with the radio but cant do the PC as the setup will not display.
Can you help???
maids is offline
post #647 of 656 Old 02-03-2016, 06:27 PM
IntelliVolume's Avatar
Quoted: 1487 Post(s)
Liked: 694
Try looking into the "IntelliVolume" feature, which I believe is under the "Source Setup" menu...
IntelliVolume is offline
post #648 of 656 Old 02-03-2016, 08:46 PM
Quoted: 14 Post(s)
Liked: 0
I tried to set this but when i put the onkyo on PC the setup display goes away
TV and radio no problem
How do i fix the PC when I cant see the setup
maids is offline
post #649 of 656 Old 02-03-2016, 09:02 PM
Liked: 694
That's strange...
Is it possible that your got a defective unit?
post #650 of 656 Old 02-03-2016, 09:05 PM
Quoted: 14 Post(s)
Liked: 0
Originally Posted by IntelliVolume View Post
That's strange...
It isnt defective we have had the unit ages, maybe its the connections
maids is offline
post #651 of 656 Old 02-05-2016, 04:50 PM
Quoted: 14 Post(s)
Liked: 0
Oh well, I'm not 100-percent sure my settings would yield absolutely ideal sound based on your husband's hearing; it really is dependent on room setup...but let me take a stab at it and you can get back to me with any thoughts...
Okay -- in the SPEAKER CALIBRATION menu of the Onkyo, try setting the FRONT LEFT channel to "+6dB", the CENTER channel to "+8dB" and the FRONT RIGHT channel to "+6dB" -- that is, IF your two main front speakers are EQUIDISTANT from your listening position (they are the same distance each). Now, scroll to the SURROUND channels and try the RIGHT SURROUND also at "+6dB" and the LEFT SURROUND at "+6dB" -- IF both surround speakers are EQUIDISTANT from your ear(s) when you're sitting in the "sweet spot." If you're sitting CLOSER to one surround channel than the other, LOWER that channel's dB level to sort of "match" the output of the other one; you'll have to test this with some DVDs and Blu-rays, etc...
If you're using a subwoofer, try leaving this on "+2dB" for the moment -- bass is another area where you have to tweak to your room and volume levels; you have to see if when you CRANK DVDs and Blu-rays if the bass is "bottoming out" from the sub and if so, REDUCE the calibration level. In my system, "+2dB" tends to shake the walls with really bass-heavy material without making the sub sound like it's gonna come apart...
If you have a setting for "LPF of LFE," set this to "120Hz".
Now, depending on what input you use in the Onkyo -- let's say "DVD/BD" -- go into the SOURCE SETUP in the SETUP menu and scroll down to "INTELLIVOLUME." Crank this up to "+10dB"...let me know when you've made these settings...
just decided to use the settings that you provided thank you.
Music sounds good for hubby on mutichanel.
Movie files I have ripped use dolby or thx cinema etc. some voices on some files sound muffled.
Do you turn off these settings somehow?
maids is offline
post #652 of 656 Old 02-05-2016, 06:02 PM
Quoted: 14 Post(s)
Liked: 0
After reading through here I would love to run Audyssey MultEQ XT32:Auto Setup”. again
The problem maybe our room and where to put the mic.
Our listening area is about 4x6 mt but it is open to a large area behind us.
If we re st Audyssey can we still manually change our speaker levels?
As not being an expert and a bit of a dummy. What other settings should we turn on or off.
I have read the manual but it is so confusing.
any help would be appreciated
maids is offline
post #653 of 656 Old 02-07-2016, 03:44 PM
Liked: 694
Not sure what you're asking here on the "settings"...
post #654 of 656 Old 04-15-2016, 08:21 AM
spencereveritt's Avatar
I am selling my 929. What should I list it for? Time to upgrade to ATMOS.
spencereveritt is offline
post #655 of 656 Old 10-13-2016, 12:21 PM
DENIJULI's Avatar
Liked: 5
I received a phone to onkyo to inform me that he will honor the warranty even though I have more than 2 months and the repairman to repair vontpayer, I am very satisfied with my arrangement with onkyo, thank you very much
DENIS JULIEN
ONKYO TX-NR929,TX-SR805,TX-SR608
DENIJULI is offline
post #656 of 656 Old 10-20-2016, 07:40 AM
iang153's Avatar
Quoted: 65 Post(s)
Liked: 25
I have a 929 and am sending HDMI audio from my samsung 4k blu ray to the bluray input of my 929 as bitstream unprocessed. I have a 5.1 setup and simply want to have the 929 decode the movies' audio appropriately - any advice on the "correct" listening settings to use for this input would be appreciated. Thanks!
iang153 is online now
Onkyo Tx Nr929 9 2 Channel Network A V Receiver
