DAC help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-01-2013, 01:02 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I like to listen to 2-channel music (CD's, mp3, etc) but I find that sometimes CD's sound a little harsh. I hooked up an old Playstation 1 and found that I liked the sound much better. Some people have compared the PS1's sound to vinyl. It seems that I tend to prefer this over the "digital" sound. Would getting a DAC help me achieve something similar? Not sure how all this works, but for example, would I connect the CD player to the DAC, and the send that into my AVR? Can you recommend some DACs that have a warmer sound, comparable to what you'd hear when listening to vinyl? Thanks biggrin.gif
milehighou is offline
post #2 of 5 Old 12-01-2013, 02:04 PM
Knucklehead90's Avatar
Quoted: 386 Post(s)
Liked: 334
The DAC you are hearing while playing the PS1 resides in the PS1 IIRC - there is only a L/R analog out jacks - no optical or coax. Which AVR do you have? Some AVRs direct all input to the DAC regardless of what type of signal is coming to it. With the PS1 being one dimensional (analog out only) a DAC is not going to improve on what you have.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #3 of 5 Old 12-01-2013, 03:44 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
I have a Marantz 1403. I figured if I just kept using the PS1, I'd be happy, but I was just wondering what I could if I wanted to use something a little more modern to play my music. I think I discovered that I like feeding my AVR analog sound, so other than using the PS1, what are some options? Right now, I have a PS4 which doesn't play CD's or music files (way to go, Sony). So I plugged in the old PS2 to play some music the other night and connected it to my AVR via optical. A few nights later, I gave the PS1 a shot via analog cables and I liked it better. Maybe what I need is a good CD player with a nice warm DAC that I can connect to my receiver with analog.
post #4 of 5 Old 12-01-2013, 03:46 PM
normanplace's Avatar
How can a receiver direct an analog ( RCA's L/R) to a DAC? It is not digital so it cannot convert....unless the receiver converts the analog to digital before sending to the DAC but why or how would it do that?
normanplace is offline
post #5 of 5 Old 12-01-2013, 08:06 PM
Worf's Avatar
Quoted: 448 Post(s)
Liked: 214
On a number of modern receivers, the analog two channel inputs lead to an ADC and the signal is processed digitally from there. This is to apply various speaker and room corrections, as well as any DSP modes for that audio (be it standard processors that translate to surround, e.g. Pro-logic, DTS Neo, etc, or special effects that the receivers support like Yamahas are known for).
On some high end receivers, they also have a pure analog path where none of that happens. Depending on the model, speaker level corrections might take place, or they may not.
Worf is offline
