Cross over research verification - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-03-2013, 04:28 AM - Thread Starter
Rusek's Avatar
Verifying research:
my system:
HTPC outputting DTS/DD directly to my YAMAHA RX-V3800 (Receiver shows DTS/DD when playing) without enhancements
Attached to:
Data from Spec sheets
Klipsch Icon WF-35 Floor Speakers (highs and 3x5.25" mids) 45-20k HZ (Bi-Amped)
Klipsch Icon WC-24 Center                                                  65-23k HZ
Klipsch Icon WS-24 Surround                                               63-23k HZ
Polk PWS505 Subwoofer 125 HZ max
in a 5.1 Format.
so, from what i have read:
Set all speakers to small due to having a Dedicated Sub
Set Sub crossover to 120HZ on both the sub and the receiver unless you get localization then lower  to taste.
set center/surround speakers to 80hz crossover.
any errors or misconceptions? additional suggestions/recommendations appreciated.
Edit:
YPAO(Yamaha Parametric Room Acoustic Optimizer) settings:
Front and Center speakers : Large
Crossover: 60hz
from what i gather setting Front speakers to large and the crossover to 60hz would output lower frequencies to both the sub and the front speakers providing additional Umph if desired.
Or does it just send downto 60 to the fronts and below 60 to the sub?
Rusek is offline
post #2 of 3 Old 12-03-2013, 12:29 PM
Selden Ball's Avatar
Quoted: 3059 Post(s)
Liked: 1496
Setting a speaker to "Small" = enable bass management -- which diverts frequencies below 60Hz from the "Small" speakers to the subwoofer.
Setting a speaker to "Large" = disable bass management -- which does not divert any frequencies to the subwoofer.
You need to enable the Bass Out setting "Both" if you want the low frequencies below the crossover setting to be sent to "Large" front speakers and to the subwoofer. See page 92 of the owner's manual. This can result in what's called "Bass Bloat" because of the way low frequencies interact with one another and with the room.
Selden
Selden Ball is offline
post #3 of 3 Old 12-03-2013, 12:43 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
Set all speakers to "small".
Set the crossovers for each channel (or channel pair) to 80Hz. (You can also experiment with setting the crossover for the main speakers to 60Hz.)
If it's not defaulted to 120Hz, set the LPF of LFE (the "crossover" for the LFE channel) to 120Hz.
eljaycanuck is offline
Klipsch Wf 35 Icon W Series Furniture Grade Floorstanding Speaker , Klipsch Wc24 2 Way Center Channel Loudspeaker Espresso , Klipsch Ws 24 Icon W Series Furniture Grade Surround Speaker Espresso Each , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Yamaha Rx V3800bl Receiver
