Avr146 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-03-2013, 07:56 PM - Thread Starter
efster421's Avatar
Today I was listening to music as i was getting ready for work i have a avr146 hooked up with some small LG speakers and a klh sub. This is the first time it turned off on me while listening to music. It was turned up to - 8db. After it turned off I turned it back on and it stayed on for about 1 minute then it went to PROTECT MODE and turned off. It only does it when i yurn it up pass 8db. And it never used to do it before. My guess it was just tpo hot ???
efster421 is offline
post #2 of 3 Old 12-04-2013, 07:22 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4955 Post(s)
Liked: 8381
Check all of your speaker cable connections. You could be experiencing a mild short that only manifests at higher voltages. However, it could certainly also be a thermal thing. Is there any dust that might be hindering cooling?
Mark Henninger
imagic is online now
post #3 of 3 Old 12-04-2013, 10:02 PM - Thread Starter
efster421's Avatar
Thanks I already found my problem. My center speaker was causing a short. I ended up blowing out my center speaker due to my dumb self having if set to LARGE on the receivers settings.
Harman Kardon Avr 146 Home Theater Receiver With Ipod Control And Hdmi Connectivity
