Help choosing a reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-05-2013, 11:25 AM - Thread Starter
Keltik30's Avatar
So I've finally purchase my speaker and now just looking for receiver to complete the setup.
I have around $500 left to spend, I have been shopping around and I am told Onkyo has a smoother sound than Denon so have been looking at their range.
The 818 is now available for $700.. I would be maybe willing to stretch to that as I am a relative newbie and from what I've read audyssey xt32 would help get the best out of my system?
I like the number of hdmi I inputs, as at the moment I need 4 and will be adding in future. Also I need at least 2 optical inputs for my PC and Blu ray, although maybe the hdmi cable can handle that from my Bluray?
I'm open to suggestions. I'm crap at budgeting, I generally start by thinking I can do with a cheaper item then find myself being convinced by brands such as THX certified, Audyssey Xt32 etc.
My speakers are 6ohm if that matters. I have read that 8ohm receivers will handle this fine.
Any help or recommendations is greatly appreciated.
Keltik30 is offline
post #2 of 14 Old 12-05-2013, 11:59 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3829 Post(s)
Liked: 3825
I think Denon sounds great myself. You could get a Denon X2000 - and I'd use HDMI from your Blu Ray player for sure. Or an Onkyo. Give me a call to discuss receivers if you want.
Keltik30 likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #3 of 14 Old 12-05-2013, 12:52 PM - Thread Starter
Keltik30's Avatar
Would you prefer the x2000 simply for the sound? It's the same price point although I have heard Denon is more trusted with their quality than Onkyo.
Onkyo seems loaded with stuff, maybe that's the trade off between Denon and Onkyo.. Quality or quality?
Keltik30 is offline
post #4 of 14 Old 12-05-2013, 01:06 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
Hopefully not since all these receivers sound the same without processing. Remember, he's an audio salesman. Yes Denon has a better reliability record than Onkyo.
FMW is offline
post #5 of 14 Old 12-05-2013, 02:26 PM - Thread Starter
Keltik30's Avatar
Thanks. I have decided to buy a cheaper AVR and put more money towards my sub.
I'm thinking the refurbished Denon 2312cl for $450 looks good?
Keltik30 is offline
post #6 of 14 Old 12-05-2013, 03:05 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3825
I may be a " salesman ", but I have my own home theater, and have owned Denon receivers since at least 2002. I personally have never had a problem with a Denon that I've owned. That's all - just expressing my experience for what its worth - we sell Onkyo and others though too.
post #7 of 14 Old 12-05-2013, 03:37 PM
afrogt's Avatar
Quoted: 1363 Post(s)
Liked: 946
The 2312CI can be had for $50 less shipped here.
http://www.accessories4less.com/make-a-store/item/DENAVR2312CI/DENON-AVR-2312CI-7.2-Integrated-Network-A/V-Surround-Receiver/1.html
Afro GT
afrogt is offline
post #8 of 14 Old 12-05-2013, 03:53 PM - Thread Starter
Keltik30's Avatar
Ah thanks you are right. I was looking at the 'you save' amount.
Is the Denon 3311 worth an extra $80 against the 2312? It seems like a more powerful amp but looses some features. Which one would be more worth my money?
Keltik30 is offline
post #9 of 14 Old 12-05-2013, 04:00 PM
afrogt's Avatar
Liked: 946
Depends what you're trying to accomplish. And its more like $100 more since you have to pay for shipping on that model....
What features do you need?
Afro GT
afrogt is offline
post #10 of 14 Old 12-05-2013, 04:10 PM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
Or throw a wrench in the works and consider this one.
http://www.accessories4less.com/make-a-store/item/YAMRXA830BL/YAMAHA-RX-A830-7.2-Channel-Network-AV-Receiver/1.html
Here's a rating on some to consider also. The Yamaha was their favorite. Good comparison chart on AVR'S.
http://www.audioholics.com/how-to-shop/best-midrange-receiver-2013
phantom52 is offline
post #11 of 14 Old 12-05-2013, 04:28 PM
Knucklehead90's Avatar
Quoted: 495 Post(s)
Liked: 423
+1 on Yamaha. I'm a recent 'convert'. I bought the HTR-7065 which is the A820 more or less. I got talked out of it by a nephew so I now have an RX-V3900. Both AVRs are easy to use and have excellent sound quality. I don't use it for 2 channel since I have an HK990 that is IMO awesome.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #12 of 14 Old 12-05-2013, 04:43 PM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
I knew I would finally convert someone over to a Yamaha. Always loved the Yamaha's although at this time I am using a H/K 7550HD and loving it. Have a Yamaha A3000 that my son is using right now. Probably have to steal it from him to get it back. My next AVR is a NAD. That T758 is calling my name. Glad your liking that 990.
post #13 of 14 Old 12-07-2013, 06:41 AM - Thread Starter
Keltik30's Avatar
Almost went with Yamaha. But Audyssey and DSX swayed the decision for me.
Just pulled the trigger on a Denon 2313ci for $400.
Thanks for the advice guys.
Keltik30 is offline
post #14 of 14 Old 12-07-2013, 07:33 AM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
You're welcome, enjoy that AVR.
Onkyo Tx Nr818 , Denon Avr X2000 7 1 Channel Home Theater Receiver
