Subwoofer output dead on Pioneer Elite VSX-33?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-05-2013, 06:35 PM - Thread Starter
jchas41's Avatar
Quoted: 28 Post(s)
I need some assistance as I'm out of ideas. I recently noticed that my velodyne dps-12 was no longer outputting any sound, after checking connections, cables and settings I've come to the conclusion that my receiver must be faulty. I tapped on my RCA cable and my sub responds, I also hooked it up to my bluray player and played a cd which produced bass. When running mcacc setup on my Pioneer it does not output test tones to my sub, I of course have my sub on and speakers set to small, crossover at 80. Everything worked fine for two years and all other speakers and hdmi outs are all functioning normal. Is it possible that just the sub output went bad? Seems so unlikely. I'd appreciate any ideas before I start looking for repair centers. Thanks.
jchas41 is offline
post #2 of 9 Old 12-06-2013, 04:04 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
More likely that the sub's amp has failed but it the LFE port on the receiver is certainly a possibility.
FMW is offline
post #3 of 9 Old 12-06-2013, 04:16 AM - Thread Starter
jchas41's Avatar
Quoted: 28 Post(s)
Would the sub produce sound when hooked up to a source or when tapping on the end of the cable if the amp is shot? I would rather it be the sub truthfully because my sub is older, I'm gonna borrow my brothers sub today and see if it works.
jchas41 is offline
post #4 of 9 Old 12-06-2013, 09:02 AM
FMW
FMW's Avatar
Liked: 1687
That will settle it. I would also hope it is the plate amp. They are easy and inexpensive to replace.
FMW is offline
post #5 of 9 Old 12-06-2013, 09:18 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Look at the bright side.
This is your excuse to buy a Cambridge 651R receiver and pitch the Japanese junk in a dumpster.
You will feel so much better and it will SOUND so much better.
Make yourself a Christmas present!
commsysman is offline
post #6 of 9 Old 12-06-2013, 11:33 AM - Thread Starter
jchas41's Avatar
Quoted: 28 Post(s)
Okay did some more testing today and it is definetly the receiver. Tried using my brothers sub and it didnt produce any sound. Switched the cable from the subwoofer out to the center preamp directly above it and bingo sound! Very strange though as it appears the only output affected is the subwoofer out. Anyways I brought it to the repair shop and am hoping its nothing major. Thanks again.
jchas41 is offline
post #7 of 9 Old 12-06-2013, 12:00 PM
FMW
FMW's Avatar
Liked: 1687
Where is the cambridge 651r manufactured?
FMW is offline
post #8 of 9 Old 12-06-2013, 12:02 PM
FMW
FMW's Avatar
Liked: 1687
Sorry to hear it. Good luck with the repair.
FMW is offline
post #9 of 9 Old 12-23-2013, 06:26 PM - Thread Starter
jchas41's Avatar
Quoted: 28 Post(s)
Well, didn't get the news I was hoping for. Although, the repair shop I used seemed totally incompetent. After "looking at it" for almost two weeks, they shop called and said that the digital board was defective and deemed the receiver "beyond repair". Honestly, I'm stunned because the only thing that seemed to not be working was the LFE out. The shop did not provide much of an answer to my questions so I was pretty pissed. I'm debating whether or not to drive it about an hour away to have an authorized Pioneer Elite shop take a look at it. The big downside there is cost, the minimum repair cost is $165.00 and it could go up from there. I did in the meantime pickup a Yamaha 2020 on clearance at Bestbuy so I can take my sweet time with the Elite since it will be just be used in game room if I get it repaired.
jchas41 is offline
Pioneer Vsx 33 Elite Audio Video Multi Channel Receiver
