Which AV Reciever? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-07-2013, 05:35 AM - Thread Starter
ThePilot's Avatar
Hello,
Looking for an AV Rec with all the 'over the air' features Built-In (Wi-Fi, Air Play, Bluetooth, etc., etc.,- no dongles), Sonys are the only ones that I can find with all those features, but prefer either a Denon, Onkyo, or Yamaha. Any suggestions on models would be appreciated.
Thank you,
The Pilot:confused:
ThePilot is offline
post #2 of 2 Old 12-07-2013, 06:11 AM
commsysman's Avatar
Quoted: 1026 Post(s)
Liked: 538
The Harman-Kardon AVR1700 has AirPlay and many other features and is under $300 at Amazon now.
That would be my recommendation.
IMO the reliability and sound quality of Harman-Kardon receivers is better than most of the others (especially Sony and Yamaha).
Amazon has a full detailed description of all its features if you look it up and scroll way down. It has AirPlay, USB input, network connectivity, etc. etc.
commsysman is offline
Harman Kardon Avr 1700 5 1 Av Receiver
