Can a class T amp be used with my pioneer vsx 822 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-10-2013, 07:23 PM - Thread Starter
pogo007's Avatar
Hi,
I am looking for a way to use my pre out to get a pair of speakers to use as front height. I just wanted suggestions to see which type of amp could be used. I thought about using a class T amp, can it be used for that purpose?
pogo007 is offline
post #2 of 4 Old 12-11-2013, 01:16 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Originally Posted by pogo007 View Post
Hi,
yest it can. which T amp you looking at? I have used a Lepai LP-2020A+ in a PC audio set up and overall wasn't all that thrilled with it. It was very noisy, especially at medium and higher volume levels. If I kept the volume level fairly low it was alright, but the volume was too low for my taste.
There are other T amps that are supposed to pretty good, but cost more then the budget lepai i used.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 4 Old 12-11-2013, 04:41 AM - Thread Starter
pogo007's Avatar
I was looking at these two,
Class T Digital Amplifier- 50watts RMS/CH- Sound Appeal- SA-100T
Topping TP20-MK2 MKII TA2020 Class T-AMP Digital Stereo Amplifier
Would they be any good?
pogo007 is offline
post #4 of 4 Old 12-11-2013, 05:30 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
I dont know if they are any good or not. they do seem more robust then the cheapie $20 one I used.
67jason is offline
