4 ohm speaker with 6-8 ohm rated receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-12-2013, 08:18 PM - Thread Starter
hma
hma's Avatar
I'm thinking of adding a 4 ohm Thiel SCS3 center channel speaker to my system to accompany 8 ohm Mirage surrounds and DCM Time Window 6-8 ohm L & R speakers with a Yamaha RX-V1400 receiver. The receiver only has settings for 6 or 8 ohms. 4 ohms is not mentioned.
Is this setup safe? If so, should I set the receiver to 6 ohms or 8 ohms?
BTW, I have the Thiel speaker (moving down from my other theater setup), so I'm willing to experiment as long as it's safe!
hma is offline
post #2 of 12 Old 12-13-2013, 01:58 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
Shouldn't be a problem and certainly not at moderate volume levels.
jdsmoothie is offline
post #3 of 12 Old 12-13-2013, 06:20 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Smoothie is right. To confirm know that I do it every day.
FMW is offline
post #4 of 12 Old 12-13-2013, 03:36 PM - Thread Starter
hma
hma's Avatar
Thanks. I will try it. Any thoughts regarding setting the receiver to 6 ohms vs. 8 ohms?
hma is offline
post #5 of 12 Old 12-13-2013, 05:58 PM
FMW
FMW's Avatar
Liked: 1681
6 ohms.
FMW is offline
post #6 of 12 Old 12-13-2013, 06:52 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Set to 8 Ohms..
Better sound and dynamics, plus more power...
Just my $0.05... 👍😉
M Code is offline
post #7 of 12 Old 12-13-2013, 07:13 PM - Thread Starter
hma
hma's Avatar
Guess I'll have to try both and compare. Will try to do it Sunday. THanks!
hma is offline
post #8 of 12 Old 12-14-2013, 09:33 PM - Thread Starter
hma
hma's Avatar
Well it worked! Speakers sound fine running at either 6 or 8 ohm setting. I'll have to do more experimenting to see if one is better than the other. No amp shutdown despite loud Blu-ray soundtrack. Thanks all.
hma is offline
post #9 of 12 Old 12-14-2013, 11:17 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
All a 6 ohm setting does is set a cap on the maximum power draw of the amplifier, its like listening with training wheels on.
astrallite is online now
post #10 of 12 Old 12-15-2013, 10:58 AM - Thread Starter
hma
hma's Avatar
Hmm. So why are the power ratings HIGHER as the setting goes from 8 to 6 to 4 ohms?
hma is offline
post #11 of 12 Old 12-15-2013, 11:58 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Because the switch kicks in a lower voltage to the amplifier, since current increases as the Ohms decrease so the amplifier doesn't overload..
Just my $0.05... 👍😉
M Code is offline
post #12 of 12 Old 12-15-2013, 12:34 PM
FMW
FMW's Avatar
Liked: 1681
Probably because the voltage swing is the same but the lower Impedance draws more current. Same voltage, higher current draw means more power.
FMW is offline
