Denon X4000 Problems. Receiver keeps shutting off and red light is blinking. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 58 Old 12-13-2013, 09:36 PM - Thread Starter
howletus's Avatar
I've only had this receiver a few months. Bought it brand new from Best Buy. It has worked for for a few months but in the last few days it has been shutting off by itself and the red light on the front panel is flashing. I can reset power from the remote and it will come back on but after a while it just shuts off again. Very frustrating as I had everyone over for the games last Sunday and we ended up having to go somewhere else. Is this what I can expect from my first Denon product?
Has anyone else had this problem? Help please!!!
howletus is offline
post #2 of 58 Old 12-13-2013, 09:54 PM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
It could very well be one of your speaker connections. Are you using bare wire or banana plugs?
Afro GT
afrogt is offline
post #3 of 58 Old 12-14-2013, 07:37 AM - Thread Starter
howletus's Avatar
I'm using banana plugs at the receiver and bare wire at the speakers. I haven't moved anything since I first hooked it up so I don't know why there would be a problem with a speaker connection. Also, I would expect that if there was a problem with the speaker connection that the problem would show up more consistently. Last night it happened 3 times within 10 minutes but after cycling power it was fine for the rest of the night.
howletus is offline
post #4 of 58 Old 12-14-2013, 03:08 PM
jdsmoothie's Avatar
Quoted: 12272 Post(s)
Liked: 5594
Visually check all of your speaker connections again, both at the back of the AVR and at each speaker. If no loose strands observed, then try resetting the microprocessor.
Note also the dedicated thread for Denon AVR E/X Owner's along with posts #3-6 in that thread ....
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134210
jdsmoothie is online now
post #5 of 58 Old 02-18-2014, 06:34 AM
cheapie's Avatar
I'm having the same issue. I'll follow the steps your recommended. I know there's no nails through the wire and i've check each speaker connection and am 99% sure there's no loose wires touching. Even removed the wall plates and added banana plugs in the boxes to make sure.
Hopefully hopefully running through the steps you listed will resolve the problem. If not, I'll call Denon.
cheapie is offline
post #6 of 58 Old 02-18-2014, 09:59 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
Disconnect all but the two front speakers from the unit. Then play it at the levels that you were during the "issue". Does it still shut down? IF not, add speakers, a pair at a time otherwise and see how it response. This might help with isolating a problem wire or speaker.
budwich is offline
post #7 of 58 Old 02-18-2014, 11:08 AM
cheapie's Avatar
it's seemingly very random and not connected to volume. it happens when i'm playing late at night at fairly low levels and when my kids are playing it loudly during the day...and anytime in between.
my first step will be to see if the blinking red light is fast or slow.
cheapie is offline
post #8 of 58 Old 02-18-2014, 02:48 PM
jdsmoothie's Avatar
Liked: 5594
How long have you owned the unit and how long after purchase did this start occurring?
post #9 of 58 Old 02-18-2014, 03:21 PM
cheapie's Avatar
I just got it. It's a refurbished unit and it first happened within a day of starting to use it.
cheapie is offline
post #10 of 58 Old 02-18-2014, 03:44 PM
jdsmoothie's Avatar
Liked: 5594
Exchange it.
toddman36 likes this.
post #11 of 58 Old 02-18-2014, 03:52 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Your first step should be to eliminate the wiring and speakers from the potential problem list. Eliminate all speakers and wires from the system at the AVR except for the main R & L speakers. If teh problem remains, work on the R & L speakers / wires.
How many of your speaker circuits have wiring in wall, and how many speaker circuits are exposed and not in wall?
I had a similar problem one time. One external speaker wire (not in wall) was "pinched" just enough to cause an overload but it was not a direct short "like a nail" in the wiring. Stuff happens.
Did your old AVR work properly?
After you eliminate all of your speakers and wiring, if the problem remains you should return that so called "refurbished" unit.
J_Palmer_Cass is offline
post #12 of 58 Old 02-18-2014, 04:54 PM
cheapie's Avatar
Almost all of the wiring is in the wall using using the correct type of wiring. I ran the wires myself after all the drywall was up so no chance of a stray screw running through the wire.
I had an HK 630 before this and never had an issue...but it may not have been as sensitize. I'll turn it in tonight and see if I can get it to work.
Would a crappy tv somehow cause this to happen? I have a Samsung Plasma that's starting to hum badly. Would some sort of signal be transmitted back down he HDMI cable?
I'll also make sure the Denon is plugged into the wall rathr than the power strip.
One more thing, I will try removing speaker sets to eliminate them from the equation but since it only happens once every couple of hours, I'll try other things first.
cheapie is offline
post #13 of 58 Old 02-19-2014, 04:47 AM
Quoted: 393 Post(s)
Liked: 118
Well if your previous AVR did not have this problem, then I suspect that your wiring and speakers are fine. I would just disconnect and run the front stereo pair for a while, and if it fails I would just returninstall the old AVR and return the new AVR.
It could easily be the new "refurbished" receiver. "Refurbished" means the original owner had a problem with the unit and returned it. The only "refurbishment" that was done was to plug in the unit and let it run for a while.
I never buy so called "refurbished" items because there is a good chance the original problem was never observed nor repaired. The amount of money you save buying a refurb is just not worth it.
post #14 of 58 Old 02-19-2014, 05:40 AM
KidHorn's Avatar
Quoted: 1383 Post(s)
Liked: 890
I agree the problem is the AVR was likely never properly repaired. Send it back.
I agree that refurbs are risky and probably not worth buying unless the savings are substantial. I bought a refurb 4311 for around $1,000 when new ones were going for $1,600+. Fortunately I have no issues with it. To me, saving $600 was worth the risk.
KidHorn is offline
post #15 of 58 Old 02-19-2014, 07:49 AM
smurraybhm's Avatar
Quoted: 1490 Post(s)
Liked: 1785
With a refurb if bought authorized you get the same one year warranty from Denon, Onkyo or whoever made it (usually, Pioneer is only 90 days on Elite). I have bought two refurbs from A4L and they are both going strong 5 years and 2 years later. I like KidHorn bought a refurb 4311 over 2 years ago because of the savings, great receiver at an even better price. There is no evidence to support your conspiracy theory that they never got repaired. If that was the case companies like the one above still wouldn't be in business years later.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is offline
post #16 of 58 Old 02-19-2014, 08:35 AM
cheapie's Avatar
Thanks for the assurance. The refurb'ed Denon actually only has a 1 year warranty. I did buy an extended warranty which covers an extra year for about $40.
cheapie is offline
post #17 of 58 Old 02-22-2014, 06:01 AM
jdsmoothie's Avatar
Liked: 5594
Check with your credit card issuer as it's possible they will add an extra year for FREE which would save you on future purchases.
post #18 of 58 Old 02-22-2014, 12:06 PM
M Code's Avatar
Quoted: 719 Post(s)
Liked: 423
Refurbs are not always the best buy..
Customer and store returns are often for a technical problem, unfortunately when the AVRs are at the refurb line they are powered ON only for a few minutes but not run for any extended time..
If they power up and pass a simple function test into the box they go..
So these intermittent problems are not caught..
A good test would be to put the AVR on a burn-in rack for a couple of hours then run the function test...
But the refurb techs are paid on "How many AVRs go through the line in an hour..."
Thats the risk of buyng a refurb..
Everyone like the $ savings but once they get into a return hassle for a refurb for freight and exchange, the next time they buy new in the box..
Just playing the odds, just like Vegas, some win and some lose..
Just my $0.05... 👍😉
M Code is offline
post #19 of 58 Old 02-22-2014, 12:52 PM
cheapie's Avatar
well...i used amazon gift cards for most of the purchase and my credit card will only give an extra year if you pay for the entire purchase with the CC.
cheapie is offline
post #20 of 58 Old 02-23-2014, 07:28 AM
jdsmoothie's Avatar
Liked: 5594
Sure. I was referring to future credit card purchases as you already have the extended warranty you bought that you can use on this purchase. smile.gif
cheapie likes this.
post #21 of 58 Old 02-24-2014, 06:17 AM
cheapie's Avatar
I haven't had a single problem since I posted the issue here...I wonder if the recent update fixed it. Fingers crossed!
cheapie is offline
post #22 of 58 Old 02-25-2014, 05:03 PM
bigscreen_bill's Avatar
I purchased a Denon AVR-X4000, through JD at AVS just over a month ago for a great price (don't send an email... make the call). Due to a death in the family the day after it showed up I couldn't hook it up until the about 14 days after I received it. Low a behold there was an issue. It started powering down on it's own after it warmed up, and the red LED would blink fast. Not always... just when it felt like it. I called JD and told him about the problem, and the fact that I already had it so long. JD was very supportive and told me not to worry about the time that had elapsed since I had it. He asked me some questions about how I had it set up and I let him know that the last thing I wanted to do was send it back. I tried everything to figure out what was wrong. I disconnected it from everything and even tried different power circuits in the house, but in the end it would still power down on it's own when it felt like it. This process took over a week, because I would try something different and think that it was OK... then a day later it would just shut down, so I would try something else. I actually got it to run for 24 hours once without powering down. When I finally decided that I had enough JD said he would take care of it. Within a day I received notice that a replacement was on the way and was given a tracking number. Just box up the old one when it comes and drop it off at UPS. It didn't cost me a thing except my time. My new unit seems to be working perfectly. My hats off to JD and AVS. This is probably the best service I have ever had. This is not the first time that I had a problem resolved by AVS in such a swift manner. I am a very happy camper.
cheapie likes this.
bigscreen_bill is offline
post #23 of 58 Old 04-17-2014, 12:05 PM
Liberator's Avatar
I've been having issues with my X4000 after some time of issue free operation. For me the issues started after upgrading the firmware to the new transparent UI firmware. Audio channel detection seems to have gotten flacky where you hear relays clicking as it tries to make up its mind what format the audio is in. Audio starts cutting out until its gone altogether after a while.
The second issue is the blinking red light. I think it does this when it gets hot, however it has also been triggered on zone 3 which I run to an Emotiva amp so the load on the Denon is minimal.
Maybe I should check into going back to the old firmware, assuming thats possible.
Liberator is offline
post #24 of 58 Old 04-19-2014, 10:40 AM
bill288's Avatar
I bought mine in jan 2014 started having problems in march. I was listening to an sacd in 2 channel mode when my right speaker lost volume. switched left speaker to right output still same problem. when I turned volume down and back up it was all right for a little bit then it did it again. was listening to tv in low volume around -24 when it went into protection fault. called denon and they said take it to authorized dealer. this is copied from receipt:
"History show DC issue-unit did not shut down for tech *[HOWEVER]- audio sounded extreamly "bassy" readjusted all speaker levels +0 and turned off dynamic EQ in setup- these settings could have caused unit to go into protect at high vol level or if there is a problem with one or more of the speakers attached to this unit- shorted or blown- repaired ground wire- 1 IC 931 regulator my have been damaged."
now I used auddessy for setup and when I checked my settings that I had written down my subs levels where -8.5 & -9.0 so if I am not mistaken the tech acutually turned them up by setting to 0. well I got it back and will be hooking up to test, mean while my onkyo 806 that was hooked before and during the denon repair had no problems. also tested speaker wire and ohms of all speakers, all tested the same no shorts.
bill288 is offline
post #25 of 58 Old 04-19-2014, 11:42 AM
Ricanmeng's Avatar
My X4000 has been sounding very digital as of late, with a harshness on the upper treble end regardless od audyssey settings. I have especially noticed this on higher volumes. This did not occur with my previous Integra DTR-80.2. This happens on both internal and external source material. Also when ramping up volume, I here digital stepping on the volume control. I have everything going preamp out to an emotive xpa-5 running Maggie MMG's.
Ricanmeng is offline
post #26 of 58 Old 06-18-2014, 03:29 PM
Liked: 0
Definitely invest in banana plugs to avoid any chances of stray wire strands engaging the system protection circuitry. Also check your manual speaker settings from the menu and make sure speakers sizes match your settings to reduce the load on the amp. If RECIEVER gets to hot it will shut off to protect itself from damage indicated by the slow flashing red power indicator. Make sure RECIEVER ventilation is not obstructed, recommend not stacking any components on top the unit unless you are using a component cooler which is similar to a laptop cooling pad. I have on as a buffer between my RECIEVER and DVR and have had no further incidents with the unit shutting off, unit keeps cool as a fridge. These component coolers are cheep and can be found on Amazon or Ebay and are a great insurance against unit failure.
Russ8270 is offline
post #27 of 58 Old 10-10-2015, 07:37 AM
Liked: 1
Problems with Denon AVR-X4000
I am also having a problem with my Denon AVR-X4000 shutting itself off randomly. This receiver has performed flawlessly since I bought it last November, 2014. About two and a half months ago it shut down for no apparent reason; the green pilot light turned to a blinking amber light.
I turned it back on and didn't have a problem for almost 3 weeks. More recently, it has been shutting down about every 2 hours. After reading
about similar experiences on this forum I made several minor changes. First, I used banana clips for each speaker connection but the problem continued. Then, I unplugged my iPod Touch from the front USB port. The unit stayed on for more than 24 hours straight without a problem
but a few days later it shut down after about 2 hours. Finally, I unplugged the receiver from the current surge suppressor and plugged it in to
another one which was connected to a different outlet. Again, the receiver stayed on for almost 24 hours straight until I turned it off. When
I turned it on a few days later it shut down after less than 30 minutes!!!
My overall reaction now is WTF! Because many other owners of the Denon AVR-X4000 are having the same problem means this unit probably
has a design flaw; the thing puts out an excessive amount of heat and that may have a lot to do with it. I haven't contacted Denon tech support because I'm sure they will say "try this" or "try that". Also, they probably know exactly what's wrong but are under orders from upper management
not to discuss it. I've already done everything I can and since the problem is so intermittent I doubt that any technician could make a successful repair.
If you have had this problem and have found a way to solve it, please share it with the group. Thanks very much.
chuck4536 is offline
post #28 of 58 Old 10-10-2015, 10:18 AM
Liked: 1
Denon AVR-X4000
One more thing about the Denon AVR-X4000 shutdown problem. If I completely disconnect the power before I turn the unit on I will not have a random shutdown problem. If I shut it off with the remote or press the power button and leave it in standby mode (amber light on) and then turn it on the next day or even a few hours later, it will shutdown within about 45 minutes to an hour. Has anyone had this experience?
If you have had the shutdown problem, try completely disconnecting the power before turning it on again. See if it stays on until you turn if off manually.
Please report your results on this forum and submit your experience to Denon tech support. They may be able to give us all a permanent solution.
post #29 of 58 Old 10-10-2015, 11:51 PM
eswaran's Avatar
Quoted: 12 Post(s)
Liked: 1
I have been struggling with the same problem as well. The 'remove from the power supply' idea seems like it's worth trying. This is my first Denon receiver and I don't have a high opinion of the brand now!
eswaran is offline
post #30 of 58 Old 10-11-2015, 02:32 AM
jdsmoothie's Avatar
Liked: 5594
The problem can be resolved by sending the unit in for warranty repair. Check Denon's website to see if there is an authorized repair facility in your local area, otherwise, send it to the factory repair center United Radio, Syracuse, NY after getting an RMA from Denon.
http://www.service-center-locator.co...ice-center.htm
http://www.unitedradio.com/consumer-electronics/
