Sound is the most important - AVS Forum | Home Theater Discussions And Reviews
Old 12-17-2013, 04:05 AM - Thread Starter
haiiyaa's Avatar
Hi Guys,
I am in the market for a new receiver for my home music system / home theater. I emphasize the music system because the receiver should be good for listening to music too, clean crisp sound overall. I am not looking for a lot of bells and whistles like airplay / bluetooth etc, since all this will go through my media center (XBMC). My requirements are
- 5.1 Channel is sufficient
- min. 3 hdmi ports
- min. 1 optical digital input
- min. 1 line out (that should work with all inputs, on my current receiver it only works if I am listening to the radio!)
- Good video out
With these requirements, can I have some suggestions on where I should start looking? I am on a tight budget and hence cutting down all other features.
Appreciate all your inputs here.
haiiyaa is offline
Old 12-17-2013, 04:11 AM - Thread Starter
haiiyaa's Avatar
Just wanted to add, i know speakers are important, and I am looking into that as well! smile.gif
haiiyaa is offline
Old 12-17-2013, 05:52 AM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 340
Not just speakers but speaker placement and room treatments make by far the most difference in sound quality.
Next is the quality of the source material, the source/dac then amplification last.
If you have the speakers, placement and room nailed down, you can pretty much get good sound with any AVR.
Sure there are differences, but they will be minimized if the rest is taken care of first.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
Old 12-17-2013, 01:45 PM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
Your requirements are pretty bar bone. I would look on amazon and newegg and see what they have on sale. For under $500, all AVRs are basically the same, so get whatever is on sale.
KidHorn is offline
Old 12-17-2013, 01:56 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
phantom52 is offline
