No Subs... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-19-2013, 09:27 PM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
Not sure where to post this question, since everything is hooked up to the AVR's, I'll start here...
I have two systems setup, when watching the same episode of the same show on Netflix I get different sound decoding between the two systems...
System #1 (Bedroom)
Sony BDP-S790 connected with an HDMI cable to a Denon AVR-3313ci
System #2 (Living room)
Oppo BDP-103 connected with an HDMI cable to a Yamaha RXA-2020
When using system #1 the AVR shows input as Multi Channel In. Everything works and sounds great.
When using system #2 the AVR shows Dolby Pro Logic, Adaptive DRC. The Subs don't work, sounds like crap.
Both BDP's have the output set to Bitstream so I don't think the issue is there. I would like to get the subs in system #2 to fire, any ideas?
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is online now
post #2 of 3 Old 12-20-2013, 12:52 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
In addition to setting the BDP to "bitstream" you must also ensure the Secondary Audio or Mix setting is disabled as well. In system #1, a front panel display of "Multi CH IN" indicates the Sony is decoding the audio and passing it as PCM rather than bitstreaming it and in system #2 the Oppo is only passing a Stereo signal. In both instances you need to reset each BDP while connected to the AVRs and then set them to Bitstream/Secondary Audio/Mix (off) as you likely simply moved them from being connected directly to the TV to the AVR.
jdsmoothie is offline
post #3 of 3 Old 12-20-2013, 11:09 AM - Thread Starter
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2575
Interesting, I'll have to check the second audio and mix settings. I will do the reset on each of the BDP's, but neither has ever been plugged directly into a TV...
Oppo Bdp 103 3d Blu Ray Player , Denon Avr 3313ci Receiver , Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver , Sony Blu Ray Disc Player Bdp S790
