Just bought the Marantz SR5008 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-21-2013, 10:41 PM - Thread Starter
vinny68's Avatar
Well not true this is my second one this week the first one didn't work right so i gave them a second chance. The first one had a video defect and marantz support couldn't trouble shoot the problem even the Hard Reset didn't even work , so I returned it to the store and bought another one.
So far so good it's only been a few hours in and it's just ok to me , but i'm not a tech.y guy nor now what to look for in a receiver I don't have wifi in it yet or blue ray. Just the tv and with the surround.I don't know what I should be looking for, a better pic. for the tv, a better sound coming out of my Cambridge Soundworks speakers. I thought my 10 yr. old Onkyo was great till it died on me. I'v heard great things about the Marantz sr5008 so i bought one but i just don't get why everyone thinks this is such a wounderful receiver. I would like to listen to all the pros and cons on what i may have missed. Or is there something a little better or something a little less thats just as good. THANKS
vinny68 is offline
post #2 of 9 Old 12-22-2013, 03:03 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4944 Post(s)
Liked: 8367
You should be able to find setup tips on the forum. Generally speaking, it's up to you to tweak your setup, that receiver has a lot of capability—it'll take a while to get the most out of it.
If you want to experience exceptional picture and sound quality, Blu-ray is a great option. The quality of your source material is what matters most.
Mark Henninger
imagic is online now
post #3 of 9 Old 12-22-2013, 05:34 AM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5503
jdsmoothie is offline
post #4 of 9 Old 12-22-2013, 10:22 PM - Thread Starter
vinny68's Avatar
Mark your right, I set up the blue ray today and the picture and sound was better, I bought the cable for the sub and the cat5 for internet and i'll set that up tomorrow.
I had this sub for many many years and I always had the speaker wires installed to this I never knew that all I needed was just one rca cable. It looks a lot cleaner back there and i'm hoping that it's going to sound even better. Thanks
vinny68 is offline
post #5 of 9 Old 12-23-2013, 11:29 AM - Thread Starter
vinny68's Avatar
how long does the audyssey setup take it's been running for about 15 to 20 minutes and I can't tell if it's done.
vinny68 is offline
post #6 of 9 Old 12-23-2013, 02:09 PM - Thread Starter
vinny68's Avatar
That's all set, but when I go into General it says that Zone 2 is setup. All my connections are to Zone 1 and in General all it shows is Zone 2 and Rename Zones. When I go into renaming zones it says Main Zone is the Main Zone and Zone 2 is Zone 2. This sounds more confusing that it is.
vinny68 is offline
post #7 of 9 Old 12-23-2013, 02:36 PM - Thread Starter
vinny68's Avatar
Now I don't have cable tv i'm sure it's something I did on the remote? all my connections are secure.
vinny68 is offline
post #8 of 9 Old 12-29-2013, 09:54 AM
MerlinBike's Avatar
I just installed a brand new SR5008 two days ago. It worked great for all of 15 hours— video, AirPlay, everything I wanted worked great. Then it asked to do a software update, downloaded the update, and then went into an update loop. I pulled the plug for a few hours, held the power button down for a few minutes, did a reset to factory settings a few times, and it still just keeps trying to update the software, ending up with a "Cannot connect OE" message. Marantz is closed on weekends, so no help there. Unbelievable! My network is fine: the Marantz even shows up on AirPlay for a few minutes when it powers on.
Any ideas?
MerlinBike is offline
post #9 of 9 Old 12-29-2013, 10:25 AM
jdsmoothie's Avatar
Liked: 5503
First note, you would be better served posting in the Owner's thread linked below ...
http://www.avsforum.com/t/1482248/the-official-marantz-sr5008-sr6008-and-sr7008-av-receiver-owners-thread/0_100
Second, try doing a network reset ...pressing/holding the PRESET CH +/- buttons on the front panel of the AVR for 4-5 seconds while powering on the unit.
Marantz Sr5008
