Help with marantz sr5005 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-24-2013, 10:20 AM - Thread Starter
surbo15's Avatar
Hi, I just upgraded my old Samsung tv to a 60f8000. I am running a harmony one remote for all components 5 speaker surround. I did not reprogram my remote. Everything turns on fine in the beginning with the tv showing the picture however the receiver goes from SAT mode to tv mode and tv is black. I have to manually on the remote change back to SAT mode. The tv shows the marantz info on the screen input:TV out: stereo. It's annoying. I read up and experienced that in smart mode and using samsung apps the sound only comes through the tv which you have to change in the menu. The sound that comes through is whatever is on tv. I am going to buy an optical cable to run from tv back to receiver. Thanks for your help. Please advise.
surbo15 is offline
post #2 of 2 Old 12-24-2013, 10:58 AM
jdsmoothie's Avatar
Quoted: 15354 Post(s)
Liked: 7508
Set Anynet+ on the Samsung to OFF if using the optical cable from the TV to the AVR.
jdsmoothie is online now
Marantz Sr5005 Audio Video Receiver Black , Samsung Un60f8000 60 Inch 3d Led Hdtv
