Yamaha Aventage RX-A2030 Pre-out question / running two pairs of front tower speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-26-2013, 12:50 AM - Thread Starter
VDiddy22's Avatar
Hey everybody,
I currently have the Yamaha Aventage RX-A2030 receiver powering Polk Audio RTI-A7's towers as fronts, A3's bookshelves as rear surrounds, and the Csi-A6 center channel speaker. The RTI-A9 towers just went on sale for a hot boxing week price so I pulled the trigger on them with a plan to move the A7's to the rear, and the bookshelves as mid-surrounds (my room doesn't really work with this). After thinking this over, and since a considerable amount of my listening is music (often in 2 channel), ...
Could I leave my setup as it is, and use the AVR's front pre-outs to an external amplifier (I'm looking at the Emotiva XPA-2), to power the A9's along side the A7's.
Will the pre-out still output signal when the AVR speaker output channels are being used? And assuming this works, would this be a good idea in regards to any timing differences or speaker interference?
Thanks in advance for any responses.
VDiddy22 is offline
post #2 of 5 Old 12-26-2013, 01:12 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Use one speaker per amplifier, one speaker per channel.
FMW is offline
post #3 of 5 Old 12-26-2013, 01:33 AM - Thread Starter
VDiddy22's Avatar
I'm not certain you understood my question... can you elaborate on that? Can I run two sets of front speakers like this?
VDiddy22 is offline
post #4 of 5 Old 12-26-2013, 02:17 AM
Knucklehead90's Avatar
Quoted: 386 Post(s)
Liked: 334
Yes you can. No AVR I know of has a function that prevents you from using the preamp outs and the corresponding internal amp channels at the same time. While it will 'work' you may want to reconsider doing this and just use the RTi9's for the front sound stage. You'll have sound waves bouncing all over the place.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 5 Old 12-26-2013, 04:06 AM
jdsmoothie's Avatar
Quoted: 12135 Post(s)
Liked: 5526
Although using a second set of FL/FR speakers for music only listening is certainly not uncommon (aka "Front B" or "Zone B"), this configuration is more often handled with a separate set of on board amps going to each set of speakers to allow for each set of speakers to be independently selected. In the configuration you suggest, the FL/FR speaker posts and pre-outs would both be hot so you would be unable to use just the "music" FL/FR speakers.
jdsmoothie is online now
Yamaha Rx A3020 9 2 Channel Network Aventage Av Receiver , Polk Audio Rti A7 Floorstanding Speaker , Polk Audio Csi A6 Center Channel Speaker , Polk Audio Rti A9 Floorstanding Speaker , Emotiva Xpa 2 Stereo Power Amplifier
