DENON AVR-X1000 feature or bug ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-26-2013, 03:57 PM - Thread Starter
aliyesami's Avatar
there are only two analog input one marked MPLAYER and other marked CBL/TV and two equivalent HDMI slots marked same.
now if I connect something to MPLAYER or CBL/TV and the HDMI inputs are not connected I hear the audio , as soon as I connect some audio source or HDMI or CBL/TV the analog channel stop working.
my mixer is connected to the analog MPLAYER and my PC audio is connected to the MPLAYER HDMI and even if I disable the audio card on pc the analog input is unusable unless I plug out the HDMI cable .
how can I use the mixer audio and pc audio together without having to unplug devices. ?
aliyesami is offline
post #2 of 4 Old 12-26-2013, 05:28 PM
Knucklehead90's Avatar
Quoted: 498 Post(s)
Liked: 430
It looks like the RCA L/R 'legacy' inputs are an endangered species - I have the 1713 Denon which the X1000 replaced in their model lineup. I knew when I bought it that it had only 2 L/R stereo inputs. It isn't a limitation for me since I have two sources that have HDMI inputs and I use the USB port on the front more than anything. It may become a limitation if I decide to plug something else in and it isn't HDMI capable. I have a tuner connected to one set of inputs since I found the Denon tuner is crap - the other is from the DVD player for when I want to play a CD. This is in a bedroom setup.
You could get one of these if you have any spare HDMI ports. Some times saving a few $'s doesn't pan out like you planned. All in all the Denon isn't half bad.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 4 Old 12-26-2013, 05:38 PM
jdsmoothie's Avatar
Quoted: 15062 Post(s)
Liked: 7267
HDMI inputs will take priority over the other digital or analog inputs when all are using the same source name. To use the audio from one of these other inputs, you must change the INPUT MODE setting from "Auto" to "Analog" if you want to listen to audio from one of these analog inputs.
For more information on your X1000, review posts #3-6 in the Denon AVR-E/X Owner's thread .....
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134210
jdsmoothie is offline
post #4 of 4 Old 12-27-2013, 12:03 AM - Thread Starter
aliyesami's Avatar
then I will have to go into setup mode and flip flop between HDMI and ANALOG modes. or if I go with Knucklehead90 suggestion of putting a stereo to HDMI box can I connect the mixer RCA output like this to the DVD or GAME HDMI port on DENON ?
Denon Avr X1000 5 1 Channel Home Theater Receiver
