How to effectively wire in 4 subs plus 2 buttkicker amps into receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-28-2013, 10:47 AM - Thread Starter
cdika17's Avatar
Liked: 27
Like title states, How to effectively wire in 4 subs plus 2 buttkicker amps into receiver?
My equipment:
Denon 4311ci- preamp
Emotiva xpa-5
Emptiva xpa-2
2 - svs pc13-ultra, one with bash amp and one with sledge amp
Total 6 buttkickers and 2 bka1000-n amp. 3 bk go to 1 bka1000-n, i have y splitters for each input on denon sub ports.
I'm wanting to add a couple subs in the rear sides of my room. Assuming i buy subs with amps like svs sb-1000's for example, i can't split anymore off my sub inputs.
How would this all work?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #2 of 2 Old 12-28-2013, 01:41 PM
Knucklehead90's Avatar
Quoted: 387 Post(s)
Liked: 334
You should be able to daisy-chain from the subs to the first buttkicker amp then daisy-chain them to each other. I would run Audyssey before connecting the buttkickers - the mic will likely pick up the vibrations from them. Most modern sub amps have an in and an out jack.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Emotiva Xpa 5 5 Channel Power Amplifier , Svs Pb13 Ultra
