How to turn off Dolby and LFE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-28-2013, 01:26 PM - Thread Starter
elMuro's Avatar
Hello
Like mentioned in the title I am having trouble with turning off Dolby Suround.
Somehow the receiver turned them on and I don't know how to turn it off.
I got the Sony STR DH520
Advice?
Thank you
elMuro is offline
post #2 of 8 Old 12-28-2013, 02:34 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
I'm not familiar with your brand but I suspect it probably works like others. The subwoofer is normally turned off in the manual speaker adjustments in the setup screen. In addition to the automatic calibration, there should be a manual setup screen that will allow you to change the subwoofer from yes to no or on to off. Of course, the subwoofer itself should have a switch to turn it off.
To turn off the surround processing most units would simply have you choose the stereo or direct mode rather than one of the surround modes.
FMW is offline
post #3 of 8 Old 12-28-2013, 02:59 PM - Thread Starter
elMuro's Avatar
I do not have a subwoofer and my multi channel settings are right. I got four speakers.
elMuro is offline
post #4 of 8 Old 12-28-2013, 03:10 PM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
In all honesty, it is not really clear what you mean by "turn off Dolby" and "turn off LFE". Can you elaborate, maybe?
If you configure your AVR as having NO SUB connected, the LFE channel will be routed into your front left and right speakers. Is this what you want to do? If not, and you really want to "turn off LFE", and not send the LFE channel to your front speakers, and drop it altogether, then leave the AVR configured as having a subwoofer; just don't connect one (obviously).
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #5 of 8 Old 12-28-2013, 04:23 PM - Thread Starter
elMuro's Avatar
Aha I did not know what LFE is doing. So then it is not a problem. Only remaining is how to turn off the Dolby Suround.
Without knowing the DH520 it is probably impossible to tell which buttons I have to press on the remote.
elMuro is offline
post #6 of 8 Old 12-28-2013, 04:58 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
LFE is the .1 part of 5.1. It is a channel containing low frequency effects - explosions and such. If you configure your system with no subwoofer, LFE content will be redirected to the L/R mains.
Dolby Surround is an encoding method used to expand stereo sources to the number of channels configured in your system. The processor uses ProLogic to do the expansion. If the source is already 5.1, ProLogic doesn't do anything as it can't expand something that is already expanded. So, you have nothing to be concerned about with movies. If you don't want to expand stereo sources, things like music CDs and SD TV shows, then turn off ProLogic in your receiver. The manual will explain how.
BIslander is offline
post #7 of 8 Old 12-29-2013, 05:36 PM - Thread Starter
elMuro's Avatar
I think I figured out why I have problems with the sound output.
Its not due the receiver it due my PS3.
I think when I start games they send Dolby Digital Signal and the receiver only forwards them.
So I need to turn off dolby digital at the PS3 probably.
But when I play music from the PS3 I get normal sounds.
As if I could find where to turn it off :(
I will turn off ProLogic, maybe this will help.
elMuro is offline
post #8 of 8 Old 12-29-2013, 07:55 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Why do you want Dolby surround turned off? How many speakers do you have in your system.
I'm pretty sure there is a button on the remote to just play a stereo mode if you want.
Afro GT
afrogt is online now
Sony Strdh520 7 1 Channel 3d Av Receiver
