bbe sound processing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-01-2014, 11:21 AM - Thread Starter
ngm714's Avatar
Any body out there using bbe audio restoration? I use one with my Carver CM 1090 amp, and recently fried a tweeter in my Polk rti8 towers. Could the bbe unit be adding too much high end? The polks recommend 250 wrms, the cm 1090 is rated at 100 per. Any ideas?
ngm714 is offline
