AV Amp HDMI & PlayStation 4 Problems - Yamaha v367 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-04-2014, 02:13 AM - Thread Starter
Hockmiester's Avatar
Morning all
I'm fairly sure I know the answer to this question but on the off chance someone has a magic wand I thought I would make a post.
I'm using a Yamaha RX V367 AV AMP with all my HDMI's going in and one out to the TV + speakers & optical etc.
When the PS3 upgraded to 3D the AMP stopped working (no picture at all in 3D mode) and after a firmware update from Yamaha this fixed the issue with 3D pass through over the HDMI.
I have a new PS4 and have connected it up to the same HDMI cable and the picture has a constant snow effect with regular flickering off and back on again.
I have...
1. Played with the PS4 settings but couldn't find anything that made a difference.
2. Emailed Yamaha about a firmware update (but didn't get a reply).
3. Connected the PS3 back up to the same cable to check the cable was working (it is).
Is there anything you can suggest or do I have to wait on if (ever) Yamaha decide to do another update (3D was 2010) on the v367?
I was hoping I didn't have to buy another AMP.
Regards
Mike
Hockmiester is offline
post #2 of 2 Old 01-04-2014, 02:16 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
A work around would be to simply connect HDMI to TV for video with optical to AVR for audio with no real loss in audio quality.
jdsmoothie is offline
Yamaha Rx V367bl 500 Watt 5 1 Channel Av Receiver Each Black
