MY ONKYO TX NR818 is OVERHEATING!!!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2014, 01:39 AM - Thread Starter
Jonathan Blanco's Avatar
~~I NEED HELP! I think that my Receiver May Be overheating. ive had this receiver for about 1 month and it is just starting to smell while I use it now. I noticed that the receiver will tick at random times while I am using it but the sound never cuts off while it makes the Ticking sound. Don't know what its doing. I have the receiver on the floor of my room with NOTHING on top so it has plenty of air to vent. But its started to smell just recently and when I touch it, it is Very Hot to the touch. I usually use this Bad boy at 78 to 85 decibels. I do a lot of Gaming and Movies on it. The reason why I started this thread is because now ive noticed that when I use the Audyssey calibration feature, It sets my level calibration too high on my speakers. For example, when I first calibrated a month ago when I got the receiver, it gave me -2.5 for front R and L and -6.5 for Center and -2.0 for Rear R and L and -6.5 for Subwoofer. I have not changed anything in my room and I have not moved any furniture at all. Now when I Calibrate I get +3.5 for Front R and L -1.0 for Center +3.5 for Rear R and L and -7.0 for Subwoofer. Mind you I have not touched any volume controls on my Subwoofer at all. this is worrying me. its like my receiver is not calibrating correctly anymore and it is overheating and starting to smell a lot! what can I do? Is this normal?
Jonathan Blanco is offline
post #2 of 4 Old 01-05-2014, 04:27 AM
FMW
FMW's Avatar
Quoted: 1414 Post(s)
Liked: 1487
It is not normal. Start by disconnecting the speakers to see if the problem persists. If the amps overheat there is an internal problem. If not there is a speaker problem somewhere - anything from an overly reactive load to a wire strand shorting out. Reconnect the speakers carefully and try again.
FMW is offline
post #3 of 4 Old 01-05-2014, 10:58 PM - Thread Starter
okay I did all that.
how do I get the Fans to turn on?   Should they turn on immediately?  or are the activated by a temperature sensor?
post #4 of 4 Old 01-06-2014, 06:13 AM
FMW
FMW's Avatar
Liked: 1487
They are activated by a temperature sensor. Assuming they are operating correctly they won't come on until and unless there is a problem.
FMW is offline
Onkyo Tx Nr818
