Should I upgrade my Denon 2807 or buy speakers - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2014, 08:33 AM - Thread Starter
rbpd5015's Avatar
Guys,
Can really use your help....
I own a Denon 2807. However my speakers are older than that and now done. Sold at garage sale.
I just bought a new 60 inch Samsung Plasma. Smart/3d. It came with a samsung blue ray also. I know however the 2807 doesn't do 3d. I do not see myself using the 3d however.
I need to figure out what to so with my remaining 500 budget?
Do I just get home theater in a box from Best buy?
Do I buy a speaker package for 500?
Do I buy just 2 nice speakers and wait?
I need some advice guys?
What is more important the AV or the Speakers.
Matt
rbpd5015 is offline
Old 01-05-2014, 09:02 AM
Selden Ball's Avatar
Quoted: 3059 Post(s)
Liked: 1496
Speakers.
When trying to get good sound, quality speakers and room acoustics make the most difference. Electronics are secondary, although automated room EQ (as provided by Audyssey in your current AVR) can help a lot if room treatments are not an option.
Selden
Selden Ball is offline
Old 01-05-2014, 10:07 AM
jdsmoothie's Avatar
Quoted: 12109 Post(s)
Liked: 5511
Agree with Selden. Your 2807 uses Audyssey MultEQ XT which is quite good, so pick up a pair of quality speakers and start saving for a sub next followed by a center speaker.
jdsmoothie is online now
Old 01-05-2014, 02:46 PM - Thread Starter
rbpd5015's Avatar
Sorry double post
rbpd5015 is offline
Old 01-05-2014, 02:56 PM - Thread Starter
rbpd5015's Avatar
Hey guys was at best buy this afternoon looking for speakers. The sales guy showed me 5.1 system for 799
http://m.bestbuy.com/m/e/product/detail.jsp?skuId=8206201&pid=1177718655876&pcatId=abcat0205004
During our convo he told me that the biggest issue with my denon 2807 is that it doesn't provide 1080p. So he recommended the following.
Run my hdmi from my comcast box to my plasma and then an optical cable to my Denon.
I currently run my cable box to my denon and then my Denon to my tv.
He said it will make my plasma look horrible.
What is your guys thoughts?
Matt
rbpd5015 is offline
Old 01-05-2014, 02:59 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
No need to repost. Being new, you need to wait to have your posts approved if you include links.
That said. Your 2807 supports 1080p video. There is no reason you couldn't run your cable box through the Denon like before. That said, your 2807 will not support 3D.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 01-05-2014, 03:12 PM - Thread Starter
rbpd5015's Avatar
Teachaac,
Sorry didn't realize this I edited it.
So am I fine then? As long as I don't care about 3d I should be fine?
Sorry best buy guy must not have known
Matt
rbpd5015 is offline
Old 01-05-2014, 03:19 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
Most of them don't. Which Samsung BD player do you have?
S~
teachsac is offline
Old 01-05-2014, 03:24 PM - Thread Starter
rbpd5015's Avatar
I got the Samsung BDF5900.
Don't know much about it, if it's good or bad but it came with the tv.
rbpd5015 is offline
Old 01-05-2014, 04:08 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
In the player settings, set the audio to PCM since the 2807 doesn't decode Dolby TrueHD or DTS-MA. Setting the player to PCM will allow your BD player to decode the audio and send it to the Denon. You shouldn't have any problems.
S~
teachsac is offline
Old 01-05-2014, 04:13 PM - Thread Starter
rbpd5015's Avatar
Teach,
What about for the samsung plasma? What settings do you recommend ?
Matt
rbpd5015 is offline
Old 01-05-2014, 04:23 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
Your best to look for TV settings in the thread for your TV.
S~
teachsac is offline
Old 01-05-2014, 04:31 PM - Thread Starter
rbpd5015's Avatar
Teach,
Sorry I'll ask in the tv section, however I was thinking you would know best way to get best audio or video quality trough my Denon receiver.
rbpd5015 is offline
Old 01-05-2014, 04:32 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
Matt
That guy was totally wrong. I've got a 2807 and it passes 1080p just fine. Before I took the receiver to my father's house I had it hooked up at home with my 50" Panny Plasma and a Panny BDT-220 blu ray player. No problems at all with 1080p video.
The 2807 remote is a little annoying but a Harmony remote takes care of that problem.
The limitations of the 2807 are that it doesn't decode TrueHD and DTS-MA, wont pass a 3D signal and only has 2 HDMI inputs. But you can let the player do the decoding. If the limited number in HDMI inputs and lack of 3D pass through don't matter then you should be fine.
Afro GT
afrogt is offline
Old 01-05-2014, 04:39 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
Teach,
Sorry. I don't have a Samsung Plasma. The settings I gave you should work without problems. If you have specific questions about the BD-F5900 there is a thread here:
http://www.avsforum.com/t/1463952/samsung-bd-f5900-owners-thread
S~
teachsac is offline
Old 01-05-2014, 04:43 PM - Thread Starter
rbpd5015's Avatar
Thanks guys so yes or no.
Should I go
Box to tv
Or run it trough the Denon. It sounds like your saying that the Denon handle 1080p just fine so run it through the Denon.
Since I will be using two hdmi more chance to have issues. What hdmi cables do most peoe recommend around here?
rbpd5015 is offline
Old 01-05-2014, 04:50 PM
afrogt's Avatar
Liked: 756
run it thru the receiver.
Get your HDMI and other cables at monoprice.com. Best bang for the buck. Get the high speed HDMI cables in whatever colors suit you best.
http://www.monoprice.com/Category?c_id=102&cp_id=10240&cs_id=1024008
and since you have no speakers that should be your next purchase.
Afro GT
afrogt is offline
Old 01-05-2014, 05:03 PM
Super Moderator
teachsac's Avatar
Quoted: 650 Post(s)
Liked: 953
I've used Monoprice, Blue Jeans, and Media Bridge from Amazon.
S~
teachsac is offline
Old 01-05-2014, 05:05 PM - Thread Starter
rbpd5015's Avatar
Thanks everyone
rbpd5015 is offline
Old 01-06-2014, 03:32 AM
BAMAVADER's Avatar
Quoted: 17 Post(s)
I have the same receiver in my game room and recently upgraded my speakers. I had Infinity TSS1100 speakers and upgraded to the Pioneer Andrew Jones series that Best Buy sells...
http://www.bestbuy.com/site/olstemplatemapper.jsp?_dyncharset=ISO-8859-1&_dynSessConf=-6603059729510965581&id=pcat17071&type=page&ks=960&st=categoryid%24abcat0205000&sc=Global&cp=1&sp=-bestsellingsort+skuidsaas&qp=brand_facet%3DBrand%7EPioneer%5Esoldby_facet%3DSAAS%7ESold+By%7EBest+Buy&list=y&usc=All+Categories&nrp=15&fs=saas&iht=n&seeAll=
They sound absolutely amazing with the Denon receiver. The Definitive Techs will sound good with movies but I would really recommend the Pioneers for movies, games, AND music. Great sound. The only thing I didn't get was the sub. I have a Velodyne impact 12 but with the money you will save on the Pioneers you could easily add a better sub. BB will match prices from Amazon now too. Good luck...
RTR
BAMAVADER is offline
Denon Avr 2807 A V Surround Receiver
