Cheapest (new) amp with 12V trigger? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-07-2014, 10:43 AM - Thread Starter
rtapia's Avatar
It can't be any more than 14" deep to fit in my cabinet. Any suggestions?
rtapia is offline
post #2 of 9 Old 01-07-2014, 10:46 AM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1958
Just to confirm: By "amp", you mean a power amp? How many channels? And is there a price restriction?
Outlaw has this amp ($379, 12V trigger, 11.5" deep), but it may not be what you're looking for.
eljaycanuck is offline
post #3 of 9 Old 01-07-2014, 02:04 PM - Thread Starter
rtapia's Avatar
Thanks for the response. I definitely need to provide more info and correct a mistake.
Looking for a receiver (not amp). Needs to have a second zone so I can run 5.1 and a 2.0 zones. My Denon AVR-2807 does everything that I need it to do, it's just too deep for my new setup. I like the Onkyo TX-NR626, except that it doesn't have a 12V trigger. There really isn't a hard budget, but I don't want to spend a whole lot extra just for a 12V trigger.
rtapia is offline
post #4 of 9 Old 01-07-2014, 02:16 PM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
What is the 12v trigger for, if I may ask?
phantom52 is offline
post #5 of 9 Old 01-07-2014, 02:28 PM - Thread Starter
rtapia's Avatar
The Denon AVR-X3000 is too deep.
The Onkyo NR-828 is too deep.
ThePioneer SC-1523-K is too deep and too expensive.
ThePioneer Elite VSX-70 is barely too deep.
The[http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-43]Pioneer Elite VSX-43[/url] might work. I need to do more research.
The[http://store.sony.com/es-7.2-channel-wi-fi-a-v-receiver-zid27-STRDA1800ES/cat-27-catid-All-ES-Home-Theater-Components?_t=pfm%3Dcategory]Sony STRDA1800ES[/url] might work too.
Did I miss any?
rtapia is offline
post #6 of 9 Old 01-07-2014, 02:29 PM - Thread Starter
rtapia's Avatar
http://www.audiophilleo.com/definitions.aspx?12V%20Trigger
rtapia is offline
post #7 of 9 Old 01-07-2014, 02:32 PM
DonH50's Avatar
Quoted: 2119 Post(s)
Liked: 1688
Remember you'll need room behind to connect wires and clearance for cooling. Can you cut out the back of the cabinet? That is what I did to mine. Easier access, better cooling, and accommodates better gear.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #8 of 9 Old 01-07-2014, 02:45 PM - Thread Starter
rtapia's Avatar
The 14" gives me the extra room that I need to make my connections. The 12V trigger will be used for supplemental fans. The more I think about it, a triggered 120V A/C plug would work too.
rtapia is offline
post #9 of 9 Old 01-07-2014, 03:16 PM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
I know what a 12v trigger does. What I meant was answered in your last post. For fan use. It's going to be hard to find an AVR for the depth you need, especially with a 12v trigger or a switched plug on the back of it. The 5.1 channel Yamaha below will meet your depth requirements but doesn't have either. You could add a power strip with the switches you need.
http://www.crutchfield.com/p_022RXS600/Yamaha-RX-S600.html
