Unable to connect my new Onkyo NR626 to my Bose Lifestyle unit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-07-2014, 10:13 PM - Thread Starter
vshivaram's Avatar
Hi,
     I have a new Onkyo NR626 which I am trying to connect to my Bose Lifestyle 6 Series II system via RCA. The Onkyo has two Sub Woofer Pre Out RCA outputs, which I have connected to the Aux In of by Bose Unit. I have tried playing with all possible menu settings on the Onkyo 626, but am not able to get any sound output through the Sub Pre Out at all. Can anyone please instruct me on what settings I need to enable/disable on the 626 to get sound from the Sub Pre Outs? I have set the Audio TV Out main to ‘Off’, so sound does not output to the TV via the HDMI Main.
Warm Regards,
Shivaram Venkatesh
vshivaram is offline
post #2 of 5 Old 01-07-2014, 11:05 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
Try running the Audyssey setup. It should detect the subwoofer and turn on the subwoofer channel output.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 5 Old 01-08-2014, 02:01 PM
Patrick Collins's Avatar
Quoted: 47 Post(s)
Liked: 44
You are using the wrong outputs. You'll only get low frequencies from the Sub Outs. Use Zone 2 Pre Outs to your Bose unit. I'm pretty sure your Bose has no speaker level inputs.
Go Niners.
Patrick
Patrick Collins is offline
post #4 of 5 Old 01-08-2014, 02:19 PM
jdsmoothie's Avatar
Quoted: 15344 Post(s)
Liked: 7501
You need only connect one of the sub pre-outs to the Accoustimass module and then as suggested, simply run the Audyssey setup procedure with the setup mic supported using either a camera tripod or ideally a mic boom stand. Review the Audyssey 101/FAQ for more helpful information.
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-51779/51700_100#post_21783025
jdsmoothie is online now
post #5 of 5 Old 01-08-2014, 02:35 PM
Quoted: 47 Post(s)
Liked: 44
If I'm not mistaken the Aux-in on the OP's Bose is full range, not a sub input.
Patrick
Onkyo Tx Nr626 7 2 Channel Network Audio Video Receiver
