Onkyo causing blank screen on ps3 and web pages after rearranging setup - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2014, 02:25 PM - Thread Starter
stegen's Avatar
Quoted: 80 Post(s)
Liked: 73
I turned my theater into a bedroom temporarily to accommodate my girlfriend and son moving in. I had all my AV stuff in a corner, ps3, onkyo ht-rc270, Epson 8700 ub hanging etc. I had to move the rack over to the other side of the room to make room for the bed. Now when I try to use my ps3 or surf the web on the projector its all goofy. what happens is on the ps3 I can not set it to 1080p otherwise the projector wont see a signal. 1080i and 720p work fine. When the pc is on, when i surf web pages almost every time I go to a different page the screen goes black and then comes back on. some times is turns on the black and on then black etc till i blindly click something else on the web browser to go to a different page. I am not sure what is going on. settings are the same on the AVR and the FP. The only thing I can maybe think of is that I have a different 25 hdmi cable running across the room now instead of the shorter one from before. Could a bad or to long run of an hdmi cable cause this? any ideas would help.
stegen is offline
Old 01-08-2014, 02:27 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 8779 Post(s)
Liked: 3983
Yup. It's the longer cable length as well as the quality of the cable. Add an HDMI repeater/extender or get a better quality HDMI cable (Monoprice or Blue Jeans Cables) and that should resolve your issue. smile.gif
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
Onkyo Ht Rc270 , Epson Home Cinema 8700 Ub Projector
taboola here
